CBX rear shocks
CBX rear shocks
Has anyone used the rear shock sets for the 1979/80 CBX available from David Silver spares, and any comments on them please
Re: CBX rear shocks
Assuming these are the ones you are asking about?
https://www.davidsilverspares.co.uk/CBX ... rt_332249/
Re: CBX rear shocks
Hi Steve, Those are the shocks. Have you tried them?
Re: CBX rear shocks
Have not tried them and unfortunately not seen any feedback about them anywhere.
I understand using the David Silver ones if you are going for a stock appearance otherwise another option would be to contact Nils about the Ikon shocks.
Yes i know shipping to SA could be a deal breaker.
viewtopic.php?f=5&t=10498
Re: CBX rear shocks
Thanks for your feedback Steve. The Ikon shocks are quite a bit more expensive, so I think I will give the David Silver ones a try.
Re: CBX rear shocks
On the other hand, you'd be getting shocks that actually work AND look good with the Ikon shocks. IOW, as always, you get what you pay for.
Re: CBX rear shocks
For something in between those two, I just bought a set of Hagon shocks and they really look well built,not cheap looking at all, unfortunately no experience on them yet as my bike isn't ready .....all in to my door in Canada for $300 Can.
Forrest Miller
- Syscrush
Re: CBX rear shocks
I'm late to this party, but I like talking about twin shock setups, so I wanna share a bit. Someone else facing the same decision might find this useful.
I wanted fancy for my bike - most people jump immediately to Ohlins when they think "damping" and "fancy", but the shock that Ohlins specs for the CBX is the HO-140 S36P. It's a good gas-charged shock and according to my favorite suspension shop the damping out of the box should be excellent. These should be a very nice ready-to-ride shock - but I wanted more adjustability than these offer (preload only), and I also wanted black & chrome instead of the gold of the Ohlins.
So, I went with YSS RG362-360 TRCL-09 with optional 20-click compression adjusters. Compared to the Ohlins:
- Pro: They're the color I wanted.
- Pro: 4-way adjustable (compression, rebound, preload, and length for YSS vs preload only for Ohlins).
- Pro: Price is a bit below the Ohlins, but with more features and similar build quality. This looks attractive but did not really work out.
- Con: Less bling. You never have to explain why you chose Ohlins - but with YSS you can get sucked into a well, actually... kind of conversation too easily.
- Con: The valving out of the box is garbage. What I saw from the shock dyno indicates an unrideable mess. When you add the cost to re-valve, it costs more than the Ohlins. Buying these shocks without having them re-valved would be an utter waste of money, IMO.
- Con: They're a progressive-wound spring. This has some theoretical disadvantages vs. straight-rate springs. I don't have any problems in practice, but I would have preferred straight-rate.
