speedometer trim ring
Hay all, The light tube inside my speedo had broken loose, so to dismantle the unit and get it back in place and secured, I had to pull off the trim ring and in the process I buggered it........well not really but its pretty rough.......
Light tube is back in place, and Ive obtained new foam mounts but now I need a trim ring.
Can anyone direct me to a source for the rings please?
Al
Al
Re: speedometer trim ring
Louis will have new or used.
https://www.usedcbxparts.com/
Was those rings ever available separately?steve murdoch icoa #5322 wrote:Louis will have new or used.
Now you have me thinking.
Is it not part #2 in this schematic?
https://www.ronayers.com/oemparts/a/hon ... tachometer
You can get them from ebay NOS, search on Honda part number 37114-422-008
I have some extra chrome rings if that is what he needs. I guess I presumed he needed the black ring that you have to pry out that you have to take off to take the gauges apart. I have never screwed up the chrome ring dissembling the gauges.
I think he’s asking for the black ring you pry off. They were never available separately. You’ll have to buy a junk one and pry off the ring.
Or if you haven't buggered the top ring too badly you can buy an extra set of the chrome trim rings, flip the extra chrome ring upside down, place it on top of the original chrome ring, then drop the gauge in, the reversed chrome ring will cover the bent lip of the top ring and you'll never notice the second chrome trim ring.
I saw this posted on FB, no idea if they're good or not.
https://www.cb750faces.com/cb750faces.n ... us3nXwTfaM
yes indeed I screwed up the crimp ring getting it off......
Ive purchased parts from CB750 faces before and quality is very good, so Im going to go with that option as I now have a local expert who has developed a jig for his lathe for rolling the crimp ring properly.
If this is the only thing I screw up during my resto Ill be pretty happy.....
Al
Al
Al, please do report back with your impressions of the new crimp rings.
I bought a set from cb750fsces.com ant they are great! You can only buy them as a set tho. Their replacement faces are just like factory too, very thick and heavy
ICOA # 6786
Bike in the garage right now:
1979 CBX1000 red
1980 CBX1000 red
1981 CBX1000 prolink
1975 gl1000 blue
1975 gl1000 red
1975 gl1000 sulfur yellow
1975 gl1000 red
1976 gl1000 sulfur yellow
1977 gl1000 black
1977 gl1000 blue
1977 gl1000 black
1978 cb750f super sport
1979 cb750f super sport
1979 CBX1000 red
1980 CBX1000 red
1975 gl1000 blue
1975 gl1000 red
1975 gl1000 red
1977 gl1000 black
1977 gl1000 blue
1977 gl1000 black
Yes, Ive ordered the set so they will all match......
