Hot and cold pipes?
Hot and cold pipes?
After a hundred mile ride I checked the temps of my headers and four of them were around 185-190 degrees and one was about 225 and the last one was about 165. I have good carb rubbers so would it be more likely due to the carb adjustment or?? The bike runs great with an occasional pop on decel. Should I take the pipe temps while idling? What might that tell me?
Re: Hot and cold pipes?
The hot one plus the "pop" sound like an exhaust leak at the header. Check the gasket or you could end up with a burnt exhaust valve.
