Fuel additives
Posted: Thu Aug 31, 2017 6:37 pm
by nwtk2007
Here in the US our gas has alcohol in it. From what I can gather speaking to some owners of vintage hot rods like the KZ's and CBX's, it causes a lot of carburetor problems with build up. I had one guy recommend running some Berrymans B-12 through each tank. It certainly helped on one of my KZ's.
Is there a consensus or opinion about the fuel additives as regards to the CBX or other old super bikes? Is there any risk to the bike with using these?
Re: Fuel additives
Posted: Fri Sep 01, 2017 6:53 am
Find non-ethanol fuel if you can - it's worth it. You should be able to in Dallas.
Re: Fuel additives
Posted: Fri Sep 01, 2017 7:53 am
by SteveG
I use 91 octane non-ethanol and add a splash of Seafoam or Stabil. If I start the bike after a couple of days (up to 2 weeks or so) it starts right up. Anything longer than that, and it has to crank for a while to get gas back into the carbs. The longer it sits, the longer it cranks.
Steve
Re: Fuel additives
Posted: Mon Sep 04, 2017 9:30 am
by hondaman160mph
I've look at the MSDSes of two products that people on the internet seem to generally say are decent fuel stabilizers. Here are what those claim they're made of:
Seafoam (
http://www.seafoamsales.com/msds-downloads.html): 40-60% Pale Oil, 25-35% Naptha, 10-20% Isopropyl Alcohol
Sta-Bil (
http://www.sta-bil.com.au/pdfs/STA%20-% ... iliser.pdf): 95% Kerosene, 5% Additive Mixture
Re: Fuel additives
Posted: Mon Sep 04, 2017 4:35 pm
by jt
I got so tired of the Ethanol fuel I started using VP C9 in the CBX and the GB500. But it is about $ 9.00 a gallon. I research on the web for another source of fuel and found that Gulf Marine make a non-ethanol fuel. It use isobutanol to replace ethanol.
"Isobutanol is an EPA Approved oxygenate containing 30% higher BTU than ethanol, while producing power beyond typical ethanol-based gasoline". "ISOBUTANOL is not hygroscopic which means it will not absorb nor accumulate water, nor will the fuels damage or affect gas tanks, gaskets, carburetors or injectors. Our fuels, using ISOBUIANOL, meet all engine makers requirements which means these fuels will not void engine warranties. The National Marine Manufacturers Association has endorsed gasoline containing ISOBUTANOL as being better that using fuels containing ethanol."
So far it really run well in the CBX. I just hope it stays around. It was $ 4 a gallon. My neighbor is a boat guy so I asked him if there were any Ethanol free pumps at a marina nearby and he told me about one. So will check that out soon.
edit: I want to add see the video in the second link.
http://gulfracingfuels.com/race-fuels/gulf-atv/
http://gulfracingfuels.com/isobutanol-a ... hanolfree/
http://gulfracingfuels.com/where-to-buy-race-fuel/
Re: Fuel additives
Posted: Wed Sep 13, 2017 5:03 pm
by nwtk2007
Thanks for the info. I hadn't thought about the marina pumps.
Re: Fuel additives
Posted: Fri Sep 15, 2017 6:25 pm
by Larry Zimmer
For what it is worth: I've used anything that comes from the pump for 20 years in my '82. What I do is put a double dose of Stabil into the tank and a double dose of Techron into it if the bike is going to sit longer than a week. Also, drain the carbs INCLUDING the fuel line if it is going to sit longer than two days. (Disconnect it at the petcock. I have by-passed the vacuum valve.) Starts and runs fine doing this even after sitting 5 months through Michigan Winter.
Re: Fuel additives
Posted: Sat Sep 16, 2017 9:36 am
by hondaman160mph
Doesn't draining the carbs drain the fuel line too?
Re: Fuel additives
Posted: Sat Sep 16, 2017 10:42 am
by Larry Zimmer
Should if there isn't an air lock somewhere.
