Rear brake wont pump?
Posted: Sun Mar 16, 2014 5:02 pm
by bhf
Hey
I have cleaned out the Master cylinder and put in new kit Winther piston and all. Also cleaned the little hole in the resioar. Put it all togethers and it wont work ?! So you have any idea whats Wrong? Sorry the bad english but im from Denmark.
Re: Rear brake wont pump?
Posted: Sun Mar 16, 2014 8:12 pm
It could be the brake caliper itself is seized.
Are you getting brake fluid to the caliper?
Posted: Mon Mar 17, 2014 12:36 am
by kbart1
I believe you need to put a vacuum bleeder on the caliper bleed screw and "pull" the fluid into and through the master cylinder before you will be able to pump it with the pedal. this is what I found with mine if you drain and clean the master cylinder. good luck!
kent
Posted: Mon Mar 17, 2014 2:02 am
If you jog the pedal a bit with the bleeder screw open it helps to let the fluid run down into the empty lines and prime it. Or at least it did on Saturday
Posted: Mon Mar 17, 2014 7:30 am
For some reason, I always have a little difficulty getting the rear master to build pressure. But it eventually does. Just takes more time.
Posted: Fri Mar 21, 2014 3:45 pm
by bhf
Thanks it worked! :)
Posted: Fri Mar 21, 2014 11:14 pm
bhf wrote:Thanks it worked! :)
What worked? The "jog with bleeder open" thing? Something else?
In any event, Yay!
Posted: Sat Mar 22, 2014 6:52 am
If you all would spring for a Mity-Vac, bleeding the rear brake is a 5-minute job, every time. The front, however, is another matter! Seriously, anyone with multiple bikes, new or old, should be changing the brake fluid every 2 years anyway. The Mity-Vac makes that job SO much easier and quicker. Only issue is you have to thread tape all the bleeders, or apply heavy grease to the base of the threads to keep from pulling air bubbles .
Posted: Sat Mar 22, 2014 3:47 pm
by bhf
I used this
http://www.harald-nyborg.dk/p4432/flowc ... seudlufter and pulled the fluid trough. It worked in 5 minutes:)
