Hi
Assuming the rear brake pedal on a 79 is correctly aligned with its shaft, and assembled:
How do we set its resting position? I guess by adjusting the length of the rear master cylinder shaft?
And if so, how many mm below the bottom of the RHS footrest should this be adjusted to?
Very kind regards
Aris
Rear brake pedal adjustment
- Kool_Biker
Aris Hadjiaslanis
ICOA # 6309
Berkshire, Windsor
ICOA # 6309
Berkshire, Windsor
- zxbob
Re: Rear brake pedal adjustment
Yes you do adjust it at the master, but "how much" would be what's comfortable for you !
Bob
Bob
- Kool_Biker
Hi,
You can adjust it the level where you feel it more comfortable.
I seems at this time at master.
MGM Live Tv Channel Streaming Free
Book says 7mm from the top of the pedal to the top of the footpeg. I just put in in the closest groove that clears the bottom of the footpeg. Seems to work out just about right.
ICOA #6266
1977 CB750K
1980 CBX
1977 CB750K
1980 CBX
