Brake Resto Question - Powdercoating
Posted: Sat Jan 09, 2010 6:56 pm
by Samelak
I will be picking up a 80 CBX soon to start restoring and I am a big fan of home powdercoating. Has anyone here powdercoated their master cylinders and calipers before? I want to make sure I will be able to tear everything down far enough to put in the oven and bake with out distorting or melting anything. Plus any tips related will be greatly appreciated.
Posted: Sat Jan 09, 2010 8:02 pm
I have powder coated brake calipers on my own bikes and I am still doing this a lot for friends. Works fine. You usually don't set the oven hot enough to distort anything. Proper plugging of the holes when spraying is really important. Also cover the flat surfaces around the brake line connections to make sure the seals sit right afterwards.
Posted: Sat Jan 09, 2010 8:34 pm
by Samelak
EMS wrote:I have powder coated brake calipers on my own bikes and I am still doing this a lot for friends. Works fine. You usually don't set the oven hot enough to distort anything. Proper plugging of the holes when spraying is really important. Also cover the flat surfaces around the brake line connections to make sure the seals sit right afterwards.
Thanks for the quick reply. I'm assuming the front and back master cylinders are good to powdercoat too. Also, what about the lower fork legs? I noticed in a resto article the person decided to paint instead of powdercoat. Any issues with those parts?
Posted: Sun Jan 10, 2010 7:16 am
by alimey4u2
Powdercoat for durablity, stove enameling for finish....
As Mike has said int he prior post, just make sure that the engineered mating sufaces are protected in the spraying process. As all components are uniformally heated, distortion becomes negligible...
Posted: Sun Jan 10, 2010 10:38 am
by Phil
As was said above, preperation is the key. I even powdered in the red dots on all of mine, what are those for anyway ?, masked them off and overpowdered with black.
Posted: Sun Jan 10, 2010 11:04 am
Phil wrote: the red dots on all of mine, what are those for anyway ?, .
Quality control marks during manufacturing/assembly.
Posted: Sun Jan 10, 2010 11:55 am
by alimey4u2
Darn & all that time I thought it signified DOT 3 brake fluid installed..
Posted: Sun Jan 10, 2010 12:07 pm
alimey4u2 wrote:Darn & all that time I thought it signified DOT 3 brake fluid installed..
As opposed to another fluid? Or just fluid installed? (which would make it an assembly QC mark)
Posted: Sun Jan 10, 2010 12:14 pm
by alimey4u2
I "assumed" it was fluid installed Mike.... Still learning after all these years..
Posted: Sun Jan 10, 2010 4:56 pm
alimey4u2 wrote:I "assumed" it was fluid installed Mike.... Still learning after all these years..
Well, that would be a QC mark, wouldn't it? Some plants use yellow paint dots, some use red, when a certain process has been completed to spec.
Posted: Sun Jan 10, 2010 5:21 pm
by alimey4u2
I still think you're right Mike, you know more about production /manufacturing protocol than I....
Posted: Sun Jan 10, 2010 5:58 pm
Posted: Sun Jan 10, 2010 6:45 pm
by alimey4u2
If that means I'm also right, I agree....
