Rear Brake Seizing
- twinegar
Rear Brake Seizing
The rear brake seized in the driveway after the first test ride. I rebuilt the caliper and it did it again and I then moved to the master cylinder and noticed that the pin that unites the cylinder shaft to the brake lever is missing. would this account for the brake pads not releasing? Is the brake pedal returning to the park position and pulling the cylinder shaft back out what it takes to release the brake?
- twinegar
I took the fluid feed tube off and see 2 ports. The feed port is open and flowing but the return port almost looks like there is no hole at the bottom of the port. I am going to use a micro bit to clear it unless someone has a better idea. I have done this on a couple of my other bikes but never on a rear master. I guess they all work the same?
- twinegar
Never mind, I found another post dealing with this.
- twinegar
It was. I used a #80 drill bit and cleared the hole. I wonder why Honda doesn't make a larger return hole. I enlarged the hole on 2 of my CB750's while I had them apart and it works fine. Maybe they use a tiny hole so when brake bleeding with the cap off fluid doesn't squirt all over the place.
Master cylinder
The reason for the small hole size of the compensating port is pressure generation. Sizewise the master cylinders are marginal. The larger the hole the farther down the bore the piston must be to start generating pressure, and they can't afford the wasted space.
Davey
- alimey4u2
- ICOA Web Video Director
Re: Master cylinder
Thanks for that Dave, makes perfect sense....Dave Ditner wrote:The reason for the small hole size of the compensating port is pressure generation. Sizewise the master cylinders are marginal. The larger the hole the farther down the bore the piston must be to start generating pressure, and they can't afford the wasted space.
Ps. We miss you...
