Plea for advice from UK
Hi fellow CBXers,
I am new to the club having already joined UK Owners Club after buying my '79 Z in September 2007.
My problem relates to an incident a couple of months ago where my rear brake siezed rather spectacularly whilst exiting a dual carriageway. The system locked and slowed me down rather more quickly than I wanted to and fortunately in a straight line.
The rear disc was literally 'red hot' the splash guard had caught fire and melted away leaving a pool of sticky plastic. I had the bike recovered home and set about my investigation.
The rear master cylinder had siezed. The disc was heavily scored on the outside edge ( about 25mm ) and even after removing the calliper, I was unable to rotate the wheel without some effort. The disc was fouling on the "V" bracket. If you looked from the rear of the bike, instead of the disc running through the gaps in the bracket ( where the calliper mounts ) it was rubbing against the outside edge of the bracket.
I realised that the disc may have been damaged by the heat.
Courtesy of the UK Chairman Mel, I was able to source a replacement disc and bracket.
In the meantime I re-built the master cylinder, new seals piston etc along with the rear calliper, I replaced the brake line with a black sheathed braided one and even replaced the pipe from the reservoir. After painting the parts where necessary, I re-assembled everything .... but found that the new disc is making contact with the new bracket exactly where the old one had. The wheel could be rotated, but there was slight resistence.... this was without the calliper fitted.
I have taken the whole thing apart, checked the disc, checked the wheel spindle, the position of the spacers... but still the same. I even replaced the tie bar that locates the V bracket..........
Any ideas??? I have sent some photos to "icoapixohio" which clearly show the problem.
I look forward to your observations.
Kind regards
Mark
Epsom, Surrey
UK
I stripped the whole system replacing
Kind regards
Mark
Epsom, Surrey
UK
Trying to get photo's posted
I am brand new to the club and currently reading the ways of getting my photos linked to my posts.........
I have submitted some photos to "ICOAPIXOHIO" the photographs illustrate the problem far better than I can explain.
In the short term, I can e-mail them direct to you, or does than go against protocol?
Mark
Mark
- alimey4u2
- ICOA Web Video Director
Your e-mail came back as an error Mark, I will PM you with my e-mail addy. Look out for messages sent ( tile above)
Hi. This is the qmail-send program at yahoo.com.
I'm afraid I wasn't able to deliver your message to the following addresses.
This is a permanent error; I've given up. Sorry it didn't work out.
I transfer my pics to, http://s70.photobucket.com/
and once there, I click on the HTML below the pic which saves it and then I paste it here. Seems to work prety well.
Reason: Cleaned up HTML for PHPBB3
- cbxtacy
- alimey4u2
- alimey4u2
Mark, Put the bike on the centerstand, straighten the handlebars, check the rear wheel for centerline by pulling a piece of fishing line on either side & comparing the gaps to the front wheel. I think you may find it may be offset to one side ?? Run a straight edge between sprockets to confirm. If that's the case you will need to dissassemble the rear wheel & inspect. Do you have a workshop manual ??
If the rear rotor is the correct CBX rotor, with the correct offset, and there is no problem with the mounting of the rotor to the wheel, the collar (shown in the picture as no. "8") is the only part that determines the location of the caliper bracket relative to the rotor.
An easy remedy would be to add a large washer on the rear axle between the spacer and the caliper bracket to move the caliper bracket outwards a few milimeters.
- alimey4u2
Thanks for the pic Mike, that definitely helps......
Now if the datum of item 3 ( bearing retainer) had moved "in" due to ( lots of scenarios but I'm going with collapsed item 11 [ bearing spacer] ) This is the same datum that contacts the brake caliper support bracket.....
Could be off track here though....Not a Comstar expert..
