Plea for advice from UK
- alimey4u2
- ICOA Web Video Director
Mark, The problem lies "if" it were a bearing failure it would be close to catastrophic, It could fail at any time with dire results.... Visual bearing inspection would be number 1 on my list. Look for obvious play (side & end play) also galling ( evident roughness in rotation) collapsed cage/ balls/rollers & discoloration....
I don't "think" ( no expert on Comstars remember) they are sealed & would therefore require cleaning (prior to inspection) & grease on installation....
If you don't have any joy, I'm sure I will be available ( second pair of eyes) before riding season...
Crushed spacer
Those parts are pretty substantial. I don't know if you'd be able to crush them before the threads on the axle stripped. I'd bet something else.
Davey
Another thought
I was looking at the wheel whilst on the bench.... Is it possible, with all the spacer and bearings in place, for the offside spacer ( the one that butts against the V bracket ) to have 'sunk' into the hub?
What I am trying to say, is... the spacer sits against the bearing inside the hub... if the bearing has shifted, even 1mm or 2mm, then this would cause the effect of the V bracket making contact ith the disc as described?
Just another one of my many thoughts on the subject.....
- cbxtacy
I just remember replacing the bearings in the rear wheel on a 79 and the bearings did not fit all the way into the wheel against the ridge machined in the wheel hub. It was like the spacer was too long. It was on a wheel that had never had the bearings out as far as I could tell. I've also had rear wheel bearing failure in a couple early CBX's. I might take apart an early 79 wheel I have and check the spacer and wheel width's but right now that wheel is in NC and I'm in CA.
YOU'RE THE ONE
YOU'RE THE ONE
- alimey4u2
Re: Another thought
Mark, The pictures show this not to be the case ? The bearing retainer "seems" (if anything) to be proud ?? This locates on the outer bearing ring. The spacer locates on the inner bearing ring. If all is bolted up tight ( which would be indicated by the factory assembled punch marks .) The only way the inner bearing ring has moved is if the wrong bearing ( incorrect width of the inner ring) is installed, incorrect installation or extreme side thrust wear . However.... the gap between the bearing retainer & the flange of the spacer seems OK ....Or is it ?? All very confusing I'm afraid.....OSCARMARK wrote:I was looking at the wheel whilst on the bench.... Is it possible, with all the spacer and bearings in place, for the offside spacer ( the one that butts against the V bracket ) to have 'sunk' into the hub
- cbxtacy
I've had numerous problems over the years with rear wheel bearings and brake rotor clearance on early CBX's. To me anything that's not Pro Link is early to clarify my terminology. On the rotor clearance problems if the caliper did not appear straight, I'd straighten out the caliper holder with a BFH. If the calpier appeared straight, I'd add shims to get clearance between the rotor and holder. The problems always been on the outside of the rotor. As far as wheel bearings go, the spacer in the wheel has always been longer then the space for it in the wheel. I don't torque the retainer down, I just get it snug and center punch it so it won't come undone. If you replace the wheel bearings and get the retainer really tight, the bearing might not last long. All the X's I've had to replace rear wheel bearings had them replaced before.
YOU'RE THE ONE
YOU'RE THE ONE
Thanks again guys
The photograph really helps.....................
As mentioned in an earlier post the distance from from face of the bearing retainer to the outside edge of the spacer was about 8mm ( would that be correct? )
I think I might just as well replace the bearings anyway??
I assume that is a "pig of a job"???
Kind regards
Mark
Kind regards
Mark
- cbxtacy
Yes it is, if the retainer has never been out, that's 28 years of corrosion holding it in. Don't try it without the proper tool. A punch won't budge the retainer usually. The bearings are inexpensive and easy to install once you get the old one's out.
YOU'RE THE ONE
YOU'RE THE ONE
Re: Thanks again guys
OSCARMARK wrote:The photograph really helps.....................
Kind regards
Mark
That is the 9mm I measured on my 79.
- cbx6ss
- alimey4u2
Correct but its the caliper support bracket that's contacting.....cbx6ss wrote:Isn't the caliper supposed to kinda float on the two mount pins with the rubber boots? When I reconditioned mine I cleaned and greased both the pins and the sleeves that seem to slide on them. This allows the caliper to align to the rotor.
/r
B
Brake Drag
If a 2mm spacer fixes it, odds are there is a wrong spacer in the mix someplace. How much clearance exists between the inside of the swing arm and the spacers when there is no tension on the axle bolt. There shouldn't be much of a gap.
Davey
I placed a 40mm dia stainless washer ( 1.5mm thick ) between the spacer and the rotor.... adjusted the chain fixed the caliper and everything is absolutely 'spot on'
The wheel spins freely and true.
My next problem came when I tried to bleed the system!!!
It seemed to take for ever for the fluid to make it to the caliper, that was when I noticed that there was fluid leaking from the bottom of the master cylinder. I had rebuilt it with new pis ton, seals and spring etc... so another master cylinder strip down!!
