Plea for advice from UK
OSCARMARK
Post by OSCARMARK »
The alignment seems fine, my problem is now that I cannot figure out how the master cylinder goes back together.
I have used a genuine Honda rebuild kit with spring piston push rod etc.. The Honda manual shows that the circlip is inserted, then the pushrod. The diagram is clear........... however it seems to make sense that the circlip retains the disc on the pushrod into the body of the master cylinder?? or am I missing something.
Spring inserted
then the small cupped rubber washer
then the piston, the next thing shown in the diagram is the circlip, then the pushrod????
Mark
alimey4u2
ICOA Web Video Director
Post by alimey4u2 »
The exploded diagram is shown incorrect. If you look at the picture before (showing the dextrous use of the snap ring pliers,) you will see that the circlip retains the pushrod.... :thumupp:
This is incorrect?
2283
alimey4u2
Post by alimey4u2 »
In reality Mike the circlip "should" be shown between "4" & "10"....
O.K.! It has been some time since I had one apart. I thought the rod was loose and only held by the rubber boot. The clip prevented the piston from coming out.
alimey4u2
Post by alimey4u2 »
If you look at page 15-15 in the 79-80 manual, the middle photo shows the circlip in the correct position. It retains the total assy....
Been a while since I have been in there too.... :wink:
alimey4u2
Post by alimey4u2 »
Page 15-16 bottom left
Rear Master Cylinder Assembly
Install primary cup & piston.
Install pushrod & circlip.
Install the boot, nut & rod eye.
OSCARMARK
Post by OSCARMARK »
Okay............ the whole thing is back together with all new internals.... as soon as I introduce fluid under gravity via the feed ( 3 ) fluid leaks out of the bottom of the cylinder passed the push rod :cry:
I have stripped and cleaned it again... this time I introduced some fluid via a syringe into the feed,,,,,,,,,,, again fluid leaks out of the base passed the push rod.
There are 2 holes in the feed cavity, a large one and a small one... both are clear. I have read somewhere that these are 'transfer ports'??
Once again guys... I throw myself at the mercy of the experts :oops:
Cheers
Mark
alimey4u2
Post by alimey4u2 »
Mark, OK the obvious (forgive me) make sure the open end of the cup it up & the correct size, it should be a slight squeeze fit. Make sure the primary cup & backup cup are not rolled. Check the master cyclinder is not scored/grooved/ oversized. Assemble the parts wetted with brake fluid & all should be well....
OSCARMARK
Post by OSCARMARK »
Thanks Larry,
I spoke with John Froude ( UK member ) who works at Hartgate Honda in Mitcham Surrey...... It seems that I have left out a seal :oops:
It seems that there is another in addition to the 'cup' seal that sits on the narrow end of the spring......
The diagram in the manual is unclear ( as it is about the positioning of the circlip ) I have to search my bench for the thing.... I don't even know what it's supposed to look like. presumably its sits on the shaft of the pushrod?
Almost there!!!!
Mark
alimey4u2
Post by alimey4u2 »
That would be the primary cup Mark, you definitely need that.. Looks like a little black rubber cup, like Tommy Coopers Fez without the tassle.... :lol:
OSCARMARK
Post by OSCARMARK »
Found it!!!!! It looks like the one that fits on the spring but has a hole through it. It is a nice tight fit on the pushrod. All fitted..... brake bled and no leaks!!!!!!!!!!!!!!! :D :D :D
The road was dry this evening so took her out for a couple of miles. Brake does feel strange, but the pads are obviously new.
I am deeply in the debt of the ICOA members who have advised me, specifically Larry.
Thanks again guys and I hope it will be a while before I have to post my next problem!!!
Cheers
Mark
alimey4u2
Post by alimey4u2 »
Gnus Mark, Hope to meet you at a rally, until then ride safe..... 8)
