1981 FRONT CALIPER ON A 79
- twinegar
Will it work?
- cbxtacy
I've put CBR600F3 wheels on a prolink CBX twice. On one I used the stock calipers with thicker pads. The rotors on the F3 wheel are thinner then 79/80 CBX rotors. The big advantage is they're floating rotors. I also cut enough weight off that bike to where it's 150lbs lighter then a stock prolink. On my turbo CBX I mounted an F3 wheel and CBR900RR calipers. Those calipers are four piston and solidly mounted. That bike is only about 40lbs lighter then a stocker. Both are excellent stoppers. The one with the stock calipers I roadraced for years and it was one of the best stoppers out there, I'd outstop others all the time. I was also racing it in vintage and there weren't others with brakes as good out there most of the time. CBX's are heavy and stopping produces heat. All that heat must be dissapated. Larger (heavier) rotors will dissapate more heat then lighter ones. Prolink rotors will stay cooler but be (much) heavier then 79/80 rotors. I have no idea which rotor will work the best. I don't have CBX's because they stop so good, I have them because they sound so BITCHIN!
Even though it is nice to have a bike that stops good. Other problems are 19" wheel/tire combos are no where as good as modern 17"ers when it comes to stopping. Modern brakes on 19"ers used hard could have a tendancy to cause the front end to wash out during hard riding/braking.
YOU'RE THE ONE
YOU'RE THE ONE
- cbxtacy
I'm wondering if the metal in the modern floating rotors disappates heat better then the metal in the rotors on our beloved CBX's. The modern bikes come with floaters, some are almost as heavy as our X's, have a much greater speed potential, and none come with ventilated rotors.
YOU'RE THE ONE
YOU'RE THE ONE
- alimey4u2
- ICOA Web Video Director
Not so Ducati, my friend I have cast iron rotors on my 916SPS. I admit, it is one of the features that separate the SPS from the Strada. But it is on it.alimey4u2 wrote:The best metal for this duty is cast iron ( highest coefficient of friction) but alas they rust very quickly. Manufacturers have gone with fashion & added stainless steel ...
- alimey4u2
- piit
Hi, as cbxtacy wrote thicker pads can be used with prolink calibers and early model rotors. I bought thicker EBC (FA69/3) pads to front. Not installed yet, but will be done in near future. Please find a link http://www.ebcbrakes.com/Assets/USA%2008%20MC%20cat.pdf
-piit-
Edit:
Page 103
-piit
-piit-
Edit:
Page 103
-piit
