Brake fluid types within 3-4
Was wanting to change the brake fluid in a bike I have. Need to use DOT 4 my shop manual says, do NOT use a silicone based fluid only glycol. I know the DOT 5 is a silicone base but on the bottle of 4 I have on my shelf is states it is a silicone base. This has me worried the flushes I have done on some of the other equipment I have flushed, Kubota RTV, Honda four wheeler, and other motorcycles i might of messed up.
Re: Brake fluid types within 3-4
Never heard of a silicone based Dot 4.
If you have indeed mixed the glycol and silicone based fluids together i would flush and rebuild the m/c, lines and calipers.
From what i have read the seals can swell and the fluid can gel.
I use Belray Dot 4 in all the bikes.
https://www.motorcyclistonline.com/mc-g ... -explained
I just returned the little bottles to Wally World for a refund, they were in a Prestone bottle, look them up on E-bay and you will see both DOT 3 and 4 are marked synthetic. I too thought this about Dot 3 and 4 brake fluid.
My bad, I was crossing the synthetic, silicone for some reason, glad as I was facing a bunch of brake problems.
- cross
I use ATE TYP200 DOT4 in all my bikes. It has higher temp rating. Little pricey though
Sasha
'82 Honda CBX
'99 Triumph TBS
'01 Honda Valkyrie
'82 Honda CBX
'99 Triumph TBS
'01 Honda Valkyrie
DOT 4 good stuff. One bottle should do a brake job.
