Rear Master Cylinder / Reservoir Hose
Posted: Mon Dec 28, 2015 12:59 pm
by jnnngs
Hi,
I am looking for a new hose to connect the rear brake fluid reservoir to the master cylinder.
I searched the site and the question has been asked before, but has anyone come up with a solution?
Paul.
Re: Rear Master Cylinder / Reservoir Hose
Posted: Mon Dec 28, 2015 9:41 pm
Are they not available stock from Honda?
According to this article Tygon 2075 in the appropriate diameter is available at McMaster-Carr.
http://www.esportbike.com/forums/showth ... p?t=142556
Posted: Tue Dec 29, 2015 8:01 am
by jnnngs
steve murdoch icoa #5322 wrote:Are they not available stock from Honda?
No - the hose appears to be NLA.
Thanks for the link, I'll take a look.
Paul.
Posted: Tue Dec 29, 2015 2:44 pm
Paul: the original hose is NLA, but there is a guy in Michigan, JR Luksik, he is here ever so often under CBXtras, he sells great replacement hose by the foot.
Posted: Tue Dec 29, 2015 4:03 pm
by tevan
EMS wrote:Paul: the original hose is NLA, but there is a guy in Michigan, JR Luksik, he is here ever so often under CBXtras, he sells great replacement hose by the foot.
I have been looking for some also but can't seem to find the braided hose like the original. Is that what Jr. has?
Posted: Fri Jan 01, 2016 4:00 am
Other Hondas from the era (CB1100F, maybe others) had hoses of the same material. The 1100F's was longer, but can be cut to length, and was still available.
Posted: Fri Jan 01, 2016 6:15 am
by jnnngs
daves79x wrote:Other Hondas from the era (CB1100F, maybe others) had hoses of the same material. The 1100F's was longer, but can be cut to length, and was still available.
Dave - thanks, CMSNL has the CB1100F hose, so will give that a try.
Posted: Fri Jan 01, 2016 9:04 am
For the rear brake hose, if the braiding isn't worn much and you can trim the frayed ends a bit, just paint the hose with the same satin black you would use on other CBX trim. It will hold up pretty well.
Posted: Wed Jan 20, 2016 1:04 pm
by cross
Ebay has them but in lengths of 3ft and up and quiet pricey at about $6 per foot. What size is that hose?
http://www.ebay.com/sch/i.html?_from=R4 ... e&_sacat=0
Posted: Wed Jan 20, 2016 5:04 pm
by jnnngs
cross wrote:Ebay has them but in lengths of 3ft and up and quiet pricey at about $6 per foot. What size is that hose?
The complication is that you need to get the correct type of hose. Apparently, standard fuel hose can't be used for brake fluid - it's typically nitrile and you need EPDM or something like that.
Paul.
Posted: Wed Jan 20, 2016 5:15 pm
by cross
Hmm, another curved ball i guess!
Thanks for posting that, i wouldn't have known
Posted: Wed Jan 20, 2016 5:29 pm
by cross
Posted: Wed Jan 20, 2016 9:44 pm
by Larry Zimmer
Thanks for the update, Sasha. That will be much quicker than CSM -- believe me!
Posted: Wed Jan 20, 2016 10:00 pm
by cross
True, we just need to verify that this is the correct size
