Engine oil pressure gauge
- alimey4u2
- ICOA Web Video Director
Bought this on E-bay from TAS Classic Motorsports "Serving the elderly for over a decade" ( felt quite at home )
Nice quality item & they sent me American candy in the box too....
Ps I have no affiliation with TAS Classic Motorsports, real or suggested. Just thought I would share...
- cbxtacy
and if you're ever stranded in the Sahara, you can pull out the little black rubber plug and drink the vodka they fill it up with (liquid filled) for life giving nourishment. That is what they fill liquid filled guages with, isn't it?
YOU'RE THE ONE
YOU'RE THE ONE
- alimey4u2
Cheap ones are filled with Glycerine & expensive ones with Silicone George, both will give you the sh!ts...cbxtacy wrote:and if you're ever stranded in the Sahara, you can pull out the little black rubber plug and drink the vodka they fill it up with (liquid filled) for life giving nourishment. That is what they fill liquid filled guages with, isn't it?
Re: Engine oil pressure gauge
Hi do you have a link for it I would like one for mine
That’s a 13 year old post, Tom, I think you may need to start from scratch.
Just checked tas have gone now does anyone else know where I can source one
I’ve looked everywhere I can think of
I used a VDO instrument when I built Randakk's 1100F a few years ago. The mounting, line connections and any machining, you'll have to DIY.
Here's that same gauge (only, no fittings) from the first post, from Amazon here in the US,:
https://www.amazon.com/CWB00060-Liquid- ... B00TYY8L2M
That gauge only goes to 60 psi. A higher reading gauge is needed since the spec for oil pressure is 64-71 psi at 4000 rpm.
Joe S
Tucson, AZ
Tucson, AZ
My bad.
Dennis Kirk has them
https://www.denniskirk.com/bikers-choic ... 910600.sku
- Duffey Lake rd.
I got my oil pressure gauge fittings from Tim's CBX.CBX-tras wrote: ↑Fri May 20, 2022 12:57 pmHere's that same gauge (only, no fittings) from the first post, from Amazon here in the US,
I just bought that gauge recently in silver and it works at idle, but then it goes off the scale when I rev it.
The glass face on off-scale gauges can shatter.
Marshall also has a 100psi gauge so I swapped out my 60psi for it.
https://www.amazon.ca/Marshall-Instrume ... 901&sr=8-6
-Scott
