Alloy Fuel Tanks
Posted: Sat Jul 02, 2022 4:17 am
Here are some pics of Herman's CBX with a nice polished alloy fuel tank said to be sourced from a CB1100R. These tanks are available from TRex Racing in Heidelburg Victoria and I understand Harris in the UK also produced replicas that occasionally come up second hand.
The standard front tank locating rubber spindles have to be moved onto the top frame tube 75 mm behind the steering head and the rear 14 mm bolt hole has to be relocated onto a flat brace set back 135 mm from the existing brace at the base of the top frame tube. This changes it from a horizontal bolt to a vertical bolt and moves it back a bit, providing a larger tank capacity. (see pics)
Moving the weight back is no good for racing but is insignificant for street use, so it is a fairly nice and simple mod to dress up a CBX and improve fuel range.
