Converting a 79 to 520 chain
hey all,
Now that I have my bike running close to perfect, Im looking to improve the running gear a little.......
I priced out a 630 chain [$220CAD] and started to think that surely 530 chain will be more than enough what with the improvements in chain technology since 1979. And I see a few posts about 530 so it must be an OK change.......
So my question is what do I need to convert to 530 chain, remembering that my engine is a 80, everything else is 79.
Al
Al
Re: Converting a 79 to 520 chain
Lots of previous threads on the subject.
CBXPerformance will have what you need.
https://www.cbxperformance.com/oscommerce/
In addition, call Louis for the cushion system on the countershaft sprocket, and also a set of '80 chain adjusters. You can just swap chain and sprockets, but the other parts will make it complete.
My bike is presently running 16 front, 35 teeth on the rear and I cant find any references to those size sprockets.....
Is this normal?
Im running all 79 frame and wheels, and an 80 motor....
The 80 motor is in place while I rebuild my 79 motor, then it will go in and Ill probably sell the 80 motor.
I have to admit I didnt know there was a difference between the 79 and 80 bikes.....I thought the changes all took place for the 81 model.
Al
Is this normal?
Al
There are over 120 differences between the '79 and '80 models.
yep now I know some of them......
Ive sorted the chain and sprocket issue with the purchase of new parts. Its should smooth out power delivery significantly as the original front sprocket was well-worn and past its use-by date.
As usual thanks for the input....
Al
Al
yup, all done - new gearing of 18/36 gives me about 200rpm lower at the legal speed limit, but most noticeably each gear is just that little bit longer making the bike much smoother....
and the 520 chain set was a great upgrade.
Al
Al
Glad you are happy with the gearing choice.
Don't know if it is typos but did you install a 530 or 520 chain?
yes, 530.....
