Guages repair
CBXJOHNNY
Guages repair
Post by CBXJOHNNY »
Ok I was installing led bulbs in my guages and I must of knock loose the metal tube inside. Now I need to take them apart to fix or send off to be restored. Whats my options. ( what's next) Thanks again
chefp
Re: Guages repair
Post by chefp »
Hi,
Where did you send your gauges to be restored?
P
CBXJOHNNY
Re: Guages repair
Post by CBXJOHNNY »
I ended up doing them myself. In the process I broke the volt gauge when removing the needle. Replaced with digital gauge ( ebay). Also put new faces on the gauge fronts looks great with led bulbs.
Re: Guages repair
Can you give some info on the led light swap and a link to the digital volt gauge you used.
CBXJOHNNY
Re: Guages repair
Post by CBXJOHNNY »
On the 12v gauges ebay item 142042914502 this one was the most accurate but more work to install. And 161014971759 not hard to install. And I got the bulbs from superbrightled.com look up bulbs for spedo and tack and removed metal scields that you do not need with led bulbs . I used bA9s for tack and spedo. Put a black dab of silicone on the top of bulb so you don't have a bright spot.
