Speedometer Cable Lube question..
What should I use for cable lube.. its making noise.. I have removed the cable from the bike and cable from the sleeve.. here are some choices let me know if any of them is recommended.. Thanks.
Engine oil
Marvel mystery oil
WD-40
White grease spray
Engine oil
Marvel mystery oil
WD-40
White grease spray
PAST:
75 Kaw 900 Z1 drag and street bike
82 Kaw GPZ 1100
85 HD Low rider (1st Hawg)
83 Kaw GPZ 750 Turbo
93 Kaw ZX1100
96 HD Standard Bagger, 96" Stroker with Nitrous 125 hp
02 BMW K1200LTC
04 Triumph Rocket III 140 hp
05 Triumph Rocket III Classic
09 HD Standard now custom Street Glide
10 Triumph Bonneville Café Type
NOW:
2018 HD Road Glide Special
79 Honda GW 1000 naked museum bike.
81 Honda CBX had Zero Miles, in storage since new, serviced and am now riding, and loving it.
82 Kaw GPZ 1100
93 Kaw ZX1100
02 BMW K1200LTC
NOW:
Re: Speedometer Cable Lube question..
My theory is to clean the cable and sleeve with something like WD40 or PB Blaster and then use a small bit of lubricant on the cable like white lithium grease on reassemble.
It could also be the speedo itself. There are a couple threads available on that subject.
Cleaned and lubed mine up with teflon lube. The outer was showing its age and looked hard, with a few cracks. This maintenance caused my speedo to bounce, so i went the route of fitting a new Honda inner and outer assembly. I was curious to see what Honda used, so pulled the inner out to check the lube and was quite surprised to see the cable LIGHTLY greased, with a fairly sticky grease.
Hope this helps. Speedo was AS NEW after the cable fitted.
Cleaned speedo cable and case with WD-40, still made noise, cleaned again and used white lithium grease, still makes noise.. can feel the vibration with my hand on cable when riding, also speedo where the cable goes into it was getting warm so I unhooked it for now. Was just wondering if the speedo may need lube inside... and who may do that..
PAST:
82 Kaw GPZ 1100
93 Kaw ZX1100
02 BMW K1200LTC
NOW:
82 Kaw GPZ 1100
93 Kaw ZX1100
02 BMW K1200LTC
NOW:
If it is the speedometer itself turn it upside down and a couple drops of lubricating oil in the cable opening might solve the problem.
You can remove the whole gauge console or just the speedo itself. You only want to use a small amount as it can fog up the inside of the lens.
It could also be the speedo drive itself at the wheel.
Here is some great info from Nick about checking that problem.
http://goldwingdocs.com/forum/viewtopic.php?t=20018
Great information thanks.
PAST:
82 Kaw GPZ 1100
93 Kaw ZX1100
02 BMW K1200LTC
NOW:
82 Kaw GPZ 1100
93 Kaw ZX1100
02 BMW K1200LTC
NOW:
Re: Speedometer Cable Lube question.. UPDATE
Ok took off the speedo, turned it upside down, (like advised) and tried to get a couple drops of oil to find its way into the cable/gears area.. left it overnight.. hit it with a drill and no noise.. Reinstalled it and it works like a champ..
Thanks for the info guys, appreciate it.
PAST:
82 Kaw GPZ 1100
93 Kaw ZX1100
02 BMW K1200LTC
NOW:
82 Kaw GPZ 1100
93 Kaw ZX1100
02 BMW K1200LTC
NOW:
