Sprocket Sizes
Re: Sprocket Sizes
Done some reading..the original tyre was a 130/90. I think a 30 profile difference could explain the higher revs..or what you guys think?
Re: Sprocket Sizes
So you have a Prolink then? 130 is the tyre size whilst 90 refers to the sidewall profile. Can you post a pic of your bike for us to see?
- cross
Re: Sprocket Sizes
There should be online resource to calculate the difference.
I rode my bike this morning and I'm getting about 4800@65mph.
There is a big difference and I think that cause is more than jut tires. I would check both gauges for accuracy,
Sasha
'82 Honda CBX
'99 Triumph TBS
'01 Honda Valkyrie
'82 Honda CBX
'99 Triumph TBS
'01 Honda Valkyrie
Re: Sprocket Sizes
Guys!!!! Motorcycle basics! The 60 aspect ratio on the 160 makes that tire about 18% smaller in diameter than the 130/90. That will produce over 1000 rpm at 6000 rpm
Re: Sprocket Sizes
Well that was actually what I had in my mind but waited until someone more knowledgeable than myself spoke up...EMS wrote:Guys!!!! Motorcycle basics! The 60 aspect ratio on the 160 makes that tire about 18% smaller in diameter than the 130/90. That will produce over 1000 rpm at 6000 rpm
Re: Sprocket Sizes
Thought so..anybody know what sprocket sizes will get revs to where they should be?
- Mello
Re: Sprocket Sizes
You could go here and play with the numbers http://www.gearingcommander.com
Re: Sprocket Sizes
mcferreira100 wrote:Its a Bridgestone Battlax 160/60 ZR18 M/C
Any chance you could post a pic of the wheel you have on your bike?
If you do start changing sprockets be careful when removing both of them watching for spacers/washers. With a different wheel and wider tire you MIGHT be requiring offset sprockets.
Re: Sprocket Sizes
Well, sorta. It makes the sidewall smaller, but it's still on an 18" rim. If the tire had an aspect ratio of zero, it still wouldn't be 18% less circumference.cbx1956 wrote:Well that was actually what I had in my mind but waited until someone more knowledgeable than myself spoke up...EMS wrote:Guys!!!! Motorcycle basics! The 60 aspect ratio on the 160 makes that tire about 18% smaller in diameter than the 130/90. That will produce over 1000 rpm at 6000 rpm
Re: Sprocket Sizes
You are absolutely, right, Rick. The 18% refers only to the sidewall. The total tire diameter difference is a tad less than 6%. The rpm effect at 6,000 is only 360 rpm.Rick Pope wrote:
Re: Sprocket Sizes
Thanks Mike, for doing the math. When I responded this morning, I was only half way through my first cup of coffee, so I wasn't going to attempt any calculations. A man's gotta know his limitations.EMS wrote:You are absolutely, right, Rick. The 18% refers only to the sidewall. The total tire diameter difference is a tad less than 6%. The rpm effect at 6,000 is only 360 rpm.Rick Pope wrote:
