Need a little advice here. My Glory Red 79 is getting darn near perfect but
one problem I've got to remedy is that the rims have got multiple scratches, gouges, from a quarter century of sloppy tire swaps. Can these things be polished up and brought back to life? Is high speed polishing the answer? If they could be polished up to a chrome like appearance I could possibly get in to that. I don't want to experiment on them and screw them up royally. Any suggestions?
79 Wheel Refurbishing
- jt
CBN,
Jeff is right on the money, they can be polished and you will have to remove the silver anodizing. It is a tedous task, and took me quite a while to do it, and in the process removed all fingerprints from the tips of my fingers and very sore. I started out with 240 grit wet & dry paper and worked through the grit size up to 600 grit and finished up with Mothers mag polished. But I think they do look nice although not original looking finish. It is very difficult to get right up to where the spoke attaches to the rim though. I have a pic I can send, if you want to see how it turned out, it's large though.
JT In Texas
the mirror every mornin'.
jt wrote:CBN,
can you resize it to 800x600 and post it here? if not send it to me and i'll do it.
cbxsix@yahoo.com
jb
- jt
A picture of your wheels would be great. Please email it direct to lesfinnigan@shaw.ca. Tell me, how do you think a process like sandblasting or bead blasting would have worked rather than working your fingers to the bone?
Thanks for the advice.
CBN
CBN
- jt
CBN,
I'll get a pic of the wheel to you tomorrow. I am not sure about bead blasting first and than polishing, in theory it sounds like it would help the process along. In fact I had ask that same question tonight to Tom N and he is not sure if helped on a item he tried. I had read on another board to b/blast first and then polish, which is why I had ask TomN. I was lucky as the spoke portion on my rims where still in nice shape and shiny, I only did the rim portion.
JT In Texas
