Is there good way to renew the rubber on footpegs?
rdragoo
Post by rdragoo »
The rubber on my footpegs is showing it's age. The rubber is worn down pretty good. I'll just bet these are pricey at Honda or they don't have them any longer. Anyone found a better way?
Thanks,
Randy
alimey4u2
ICOA Web Video Director
Post by alimey4u2 »
Chris is one of our experts on pegs & should reply soon....Other than stock we have "Oberon" in the UK making quality billet anodized pegs.... 8)
Louis
Amazing Poster
Amazing Poster
Post by Louis »
Have plenty of good used ones and some NOS ones as well if you still need one.
Worlds Largest supplier of Used CBX Parts in the World. WWW.USEDCBXPARTS.COM
Re: Is there good way to renew the rubber on footpegs?
Post by Phil »
rdragoo wrote:The rubber on my footpegs is showing it's age. The rubber is worn down pretty good. I'll just bet these are pricey at Honda or they don't have them any longer. Anyone found a better way?
Thanks,
Randy
Yes they were pricey but no longer available from Honda.
Chris
Amazing Poster
Amazing Poster
Post by Chris »
Thanks,
Randy
I thought that there was a member that was offering to do this for $95 per peg?
I think also, that maybe www.cbxman.com offers this?
The rebuild involves using replaceable rubber from a later model Honda that has very similar pegs. Rubber is held on with separate, steel parts and screws are inserted through the pegs. I did this on a set of my pegs and I like them. They have more cushion than a stock peg.
I hope someone else can supply more details on the part numbers used in the repair.
cbx4evr
Post by cbx4evr »
I wrote a Tech article for this and it is posted over at http://www.cbxworld.com in the Tech section. Complete with pictures and part numbers. Check it out.
Basically you use the replaceable rubbers that are on the CX650T pegs. Requires removing the rubber from the CBX peg and drilling a couple of holes in the bottom to attach the new ones. Unfortunately, since I wrote that article, Honda no longer has the metal mounting plate available, however if you are half handy with metal you should be able to fab one. As far as I know the rubber portion is still available.
Cost is significantly lower than a CBX peg - new or used. The difference in the rubber is so subtle that no one but you will know it's different.
Terry
Post by Terry »
CBX4evr, My pegs are worn but I'm not planning on refurbishing them anytime soon but just so you know, a number of us here cannot access CBXW. If you'd like to post the article here, please do.
alimey4u2
Post by alimey4u2 »
I have been sent this by a friend, I hope I haven't upset anyone by posting it.....
I came across this while surfing the web. Hope it helps,
Rich Pleines
ICOA Member #1882
I have seen a the last few emails.. talking about foot peg
replacements..
Over here in Northamerica any way .... Honda has made a replacement..
it is used on the CX 650 . and the CB 1100f ( CAN. ) bikes... over in
U.K. maybe the CB 900f ?? not to sure ..
you will need to do some work..
first get the old rubber off. no easy task.. drill, grind, sand ,, but
it will come off..
next you will need to order from your HOnda part's dealer. the bolts and
screws. can be aftermarket..
2 - 50661 - 425 - 700 rubbers
2 - 50619 - mc7 - 000 special plates.
4 - bolts' ( metric )
4 -lock washer
4 - washers.
You will have to drill two holes in each peg.. straight down.. a bit
off figuring out.. and presto.. it all comes together.. Only the sick
real crazy CBX man like myself will very notice the difference.and you
will have a better riding foot rest.. that in the future will be full
replaceable..
. should be able to do both pegs for under 45.00 bucks..
Good luck
J.R.
Another version..........
Len: OK, here's the skinny, Cut off as much as the old rubber as poss. Use a
wire wheel to get the rest off. Use the new rubber #1396373 with stopper
plate # 1396365 to mark screw holes. Drill out with a drill bit. On the
bottom, grind off two flat spots for the bolts and washers to rest flat and
square on the peg.
Foot Peg Rubber 1396373
Plate, Foot Peg Stopper 1396365
Bolt, Hex 5X25 0207852
Bolt, Hex 5X28 0222703
Plus 4 washers and lock washers 0r use the easy way out, buy the complete
rebuildable peg assy
Right 1396381
Left 1369399
All numbers from a CX 650 Turbo 1983 Model. The are the American Honda
numbers, for Canadian numbers, get the fiche numbers from your local Calgary
Honda dealer for CX 650 Turbo. I dunno if all the parts are still available.
You owe me a Corona for this, Len. All others, well, send me a Corona if you
use this info.
And, all this info is available in Tech Tip Chronicles from Mike Nixon of
the ICOA.
alimey4u2
Post by alimey4u2 »
Thanks for the pics Nick.... 8)
cbx4evr
Post by cbx4evr »
alimey4u2 wrote:Thanks for the pics Nick.... 8)
No problem. More added.
Chris
Amazing Poster
Amazing Poster
Post by Chris »
I wasn't able to get the 50619-MC7-000 part back when I did my foot pegs. I thought about making the parts like Honda did with nuts welded on for the screws. What I ended up doing was making the parts out of thin steel plate and then just drilling and tapping for the screws. It was relatively easy to do.
alimey4u2
Post by alimey4u2 »
A picture is worth 1000 words..... :thumupp:
cbx4evr
Post by cbx4evr »
After doing this mod to my pegs some one asked me about using a different fastener and mounting it flush. I found some 5mm stainless steel allan head type bolts and put a 5mm deep counter bore on the peg. Turned out very well I must say.
Chris
Amazing Poster
Amazing Poster
Post by Chris »
cbx4evr wrote:After doing this mod to my pegs some one asked me about using a different fastener and mounting it flush. I found some 5mm stainless steel allan head type bolts and put a 5mm deep counter bore on the peg. Turned out very well I must say.
I like it! Great idea.
alimey4u2
Post by alimey4u2 »
Need a little stain on the deck Nick, apart from that, very pretty work.... 8) :lol:
