79/80 Parts List and Addendum
I'm needing either a hard copy of the 79 Parts List & 80 Parts List Addendum or a PDF of same collated from good quality scans of the hard copy.
Re: 79/80 Parts List and Addendum
Don't know if the '80 addendum is at the end.
http://www.cbxclub.com/manuals
I checked those out but they didn't fit the bill.
Thanks!
Thanks!
- spencer
Are you looking for something specific that is not in one of those lists? I don't know where you are going to find a more complete list.
SCH Rochester, MN
These parts lists were books that Honda published OUTSIDE the U.S. They include bikes of non-U.S. specs. If you are looking for parts that were on U.S. bikes only, you will not find them. The U.S. dealers had microfiches not printed material.
I was mainly after decent quality exploded views showing the 79/80 SEAT and REAR FENDER fiches. The images taken from dealer fiches are crap quality whereas the ones from published material overseas are well defined. I went ahead and used one of the quality REAR FENDER images and made the alterations using the 79/80 fiche as a guide. I'll do the SEAT one and later the rest of the 79/80 fiche views using the same process. Maybe it's a bit anal to want clear views but that's what I strive to acquire.
What about this? Anyone have one? Does it show the 79/80 drawings like below.
http://www.ebay.com/itm/381621765994?ss ... 1436.l2649
#9 on the 80 grab bar should read #10.
Did you read the description in the ebay auction the link goes to?
The seller has no clue. He sells a repro/reprint of the 1979 model parts catalog and says it applies to 1980-1982 models "with minor cosmetic differences"
No, I just saw it and asked. Looks like my meager talents at graphic drawing will be put to use after-all. My oldest son does it for a living so maybe I can bribe him.
My CBX-Z, CBX-A parts catalog (No 2) in printed form (13422Z42) shows a different picture in section F-26.
The rubber bumper on the 1979 model is item #12 and p/n 84104-422-000. The 1980 model rubber bumpers (2) are identified as item #13 and part-number 84105-469-000.
They are not the same rubber bumbers on the two years.
If you definitely want one of these catalogs, I have a spare one I will sell you.
Brace yourself, however, it will be pricey. You can ask Louis first, how much he charges for one.
I sent a PM.
This is basically what it looks like. This one is for the CBX-B (1981) only
http://www.ebay.de/itm/Honda-CBX-CBXb-1 ... SwPc9WyIqX
