ZZp or ZDDP
ZZp or ZDDP
Postby kbart1 » Sun Oct 04, 2015 11:38 pm
hey guys
so i recently purchased a '65 mustang and my gear head bro-in law was telling me to make sure i get some ZZP or ZDDP into the motor oil. it is supposed to replace the zinc content found in older motor oils back in the day. he claims it helps save wear on the valve train / camshaft. when i read about it they mention it for the single overhead camshaft Honda's as well, for example my '70 cb750. anybody ever heard of this stuff? used it? recommend it? i am wondering about the wet clutches in our bikes and one thing for sure the CBX has is a pretty elaborate valve train.....
thx
Kent
kbart1
Images: 63
Re: ZZp or ZDDP
Postby EMS » Mon Oct 05, 2015 8:46 am
Warning! : Oil Thread!
Yes, ZZP/ZDDP is important for flat "tappets" or lifters like in most older OHC engines. Some higher weight motor oils do still have 1200 or more ppm of the stuff. For your Mustang, check out Mobil1 20W-40, if you can find it.
For the CBX, use a motorcycle specific 20W50. last time, I changed oil, I found a decent priced Valvoline. ( I am not paying $8.- for a quart of oil!)
To be understood is the exception
To be misunderstood is the rule.
Images: 1716
Re: ZZp or ZDDP
Postby SteveG » Mon Oct 05, 2015 9:17 am
And STP Oil Treatment has the ZDDP. I don't know what the ppm would be, but the bottle says it has it.
Steve
SteveG
Images: 112
Re: ZZp or ZDDP
Postby harvey » Mon Oct 05, 2015 11:49 am
You might want to Google "ZDDP" to get some additional info and check at amazon.com for availability.
harvey
Ride Safe and Ride Often
harvey
Re: ZZp or ZDDP
Postby Lash » Mon Oct 05, 2015 12:54 pm
http://www.autopartscanadaonline.ca/zdd ... additives/
In Ontario, fast shipping, I bought a 6 pack to start..
Lash
Re: ZZp or ZDDP
Postby kbart1 » Mon Oct 05, 2015 6:53 pm
so would the cbx be considered a "flat tappet" motor? the stuff wont hurt the clutch or trans? 20-50 in a CBX? in my temps in Canada should it not be 10-40? sorry for all the questions!
thx
kent
kbart1
Images: 63
Re: ZZp or ZDDP
Postby EMS » Mon Oct 05, 2015 7:15 pm
Yes, the CBX is a "flat-tappet" motor. The cams contact a flat surface. The zinc composites have no negative effect on transmission or clutch. If you are concerned about using 20W50, you can use 15W30. Remember for cold temperatures, the lower rating is what counts. Not much difference between 15 and 20. But for an air-cooled engine, which have a tendency to run hot in the summer, even at 70°F (or 20°C) ambient, I'd rather be on the safe side with a 50.
Images: 1716
Return to OILS: Specs, Opinions, Preferences, and more
Who is online
Users browsing this forum: No registered users and 1 guest
