When adjusting valves, do I need the valve lifter holder tool or is there another tool to use. Also are the shims that need replacing very common to purchase? Because I have not taken the valve cover off I am not familiar with shims. How do they stay in place?
adjusting valves
- CBXRoger
Shims
The lifting and holding tools are the only way to go. After you pull the cover, and measure the clearances of all the valves, you will note which ones are out of spec. At this point, you have to determine the thickness of the shim on each of the out of spec valves and write it down. You may be able to swap some to bring them into spec. After that, post which shims you require and someone may swap with you for what you need. Or, contact your local dealer for the needed shims.
If you don't have a shop manual, it is time to get one.
Rger
PS. Shims from other brands of motorcycles may be interchangeable.
Rger
The buckets have a small rim that extends above the surface. The shim sits on top of the bucket and is held inside the rim. You will need a small pick or tweezers to remove the shim. The hold-down tool can be substituted but the original one is shaped so it holds down both valves and makes the process easier.
- SteveG
Re: Shims
Yes indeed. Read the manual, it makes the process nice and clear.CBXRoger wrote: If you don't have a shop manual, it is time to get one.
Rger
I hit my Yamaha dealer up for the shims, a couple bucks each and I am on my way.
Steve
I've been told that the FJ series Yamahas used the same shims, as did some Geo cars.
You'll probably be surprised at how few of your valves are out of spec. In all the times I've checked my valves, I've had to swap two shims.
The hardest part of the job is getting the valve cover gasket in correctly.
- CBXRoger
The cover gasket has to be glued to the cover, so it can be inverted to put it in place. There is one tall bolt head that will try to snag the gasket. With one of your wife's spatulas, working from the rear and holding the gasket, you can slide the cover in place without losing the gasket.
Roger
Roger
