For those of you that saw and heard my silver '79 at Mid-Ohio, you know I was pretty sure the whine was the primary shaft bearing on the clutch side. I got the engine out and apart yesterday and that's exactly what it was. The bearing sounded like it had gravel in it instead of balls. It hadn't started shedding pieces yet, but would have soon. I've heard of 2 or 3 of these bearings failing. It may have to do with the alternator plates burning up and getting the shaft so hot that sludge builds up in the oil path inside. That may starve the far side bearing. The bearing nearest the alternator was fine.
Anyway, I just put a good spare shaft back in and buttoned it up. It's sitting on the bench for some paint touch-up before reinstallation. Looks like it will make someone a very nice rider.
Primary shaft bearing
- alimey4u2
- ICOA Web Video Director
