Camshaft for cylinders4-5-6 intake
Posted: Sat Jun 07, 2003 7:49 am
by Joe Perkins
Does anyone have an intake camshaft for cylinders 4-5-6 for sale? Coupling to teeth on mine broke when my cam chain snapped. Piece on one side between to bolts is gone, 1/2 of each bolt exposed. Anyone know if this can be repaired? I realize it will be difficult to rebalance if I fill in the gap by welding it.
Re: Camshaft for cylinders4-5-6 intake
Posted: Fri Jun 13, 2003 1:42 pm
by cbxrider80
I have an 80 with 20,000 on it. I can sell the cam to you, if it will match.
cbandrews@texoma.net[/url]
intake cams.....
Posted: Fri Jun 13, 2003 7:28 pm
by sr71cbx
------Better verify which year your CBX is,Joe...cam timing varies between the years.You may want to just get a matched set of intakes to replace the bad one,otherwise,it may run funny with different cam timing between the left & right side of the engine
4,5,6 cam
Posted: Sat Jun 14, 2003 9:59 am
by bob
I have a right 79 intake cam if you need one still. Bob at
cbxwest@aol.com
