O ring on oil filter bolt, is it available?
Title sz it all. Does Honda still have them? My local dealer went bankrupt so I'll have to find another to order one if still available. Suppose they are?
- cbxtacy
- cbxtacy
Don's right. Lots of times I get a new filter (from Honda) the little o ring is inside the filter. Word of advise-whenever doing a filter change, check in the filter for the little o ring. It's a bitch to get off and I only replace it if the old one is brittle. I've never had one leak there.
YOU'RE THE ONE
YOU'RE THE ONE
- cbxtacy
Just so I don't look (too) stupid, I only changed the oil filter housing, not the filter as in an oil and filter change. My old OE housing had some stress cracks around the bolt hole and I figured (that) was why it was seeping around the bolt hole. Maybe its the O ring and the hairline cracks weren't causing the leak after all.
- SteveG
- cbxtacy
the washer keeps the spring from digging into the rubber on the filter. If you change it regularly it shouldn't be any problem. A lot of times when you change the filter, the washer sticks to the old filter. That's why most CBX's don't have the washer. I think all CBX's I've owned except for one didn't have the washer. They're still available. Bikebandit.com has them for $2.89.
YOU'RE THE ONE
YOU'RE THE ONE
