Cruizinimage piston rings
madjack4
Re: Cruizinimage piston rings
Post by madjack4 »
Hi i had a problem with a CI big bore kit i fitted to my 73 kawasaki Z1 it smoked and burnt oil on all 4 pots straight after it was built when i stripped it i could not find a problem ring gaps were in spec all seemed well until i removed the oil control rings and inspected the spring ring that holds out the 2 oil rings it was too small in length so was not forcing out the control rings i ended up finding some Renault clio car rings the same size its now run perfect for last 2500 mile got to be careful with the CI parts
jt
Post by jt »
In my search I also found the Yamaha XS650 bunch were using car rings with there CI pistons.
JT In Texas
the mirror every mornin'.
bikeymikey748
Post by bikeymikey748 »
And…BOOM ! That was FAST ‼️
Super impressed. One question though: I’m used to chrome-facing on the first compression ring. That’s what was on my original set of CI rings. These newest ones seem to have some sort of plasma coating (?). Does anyone have experience with these?
In the photos, original ring on the left, new one on the right.
Crazy Canuck
Post by Crazy Canuck »
Maybe it's a Moly faced ring.....
Forrest Miller :thumupp:
bikeymikey748
Crazy Canuck wrote:
Mon Feb 21, 2022 2:49 am
Don’t think so, it’s a very hard surface.
