#4 spark plug smokes !
I am suspecting there may be an issue with plug seat.
The spark plug sits in nicely and no cross thread issues. I torque it down to 13 NM and all good.
Once bike heats up , I see smoke come from somewhere near #4 plug. The speed of smoke rises and falls with throttle. No visual sign of any oil leak from cam cover either.
Any ideas ? I am suspecting the seat on the head where plug threads may have some uneven surface ?
1979 CBX (faster Red)
1981 CBX Streetfighter
2017 Aprilia Tuono.
2017 Aprilia Tuono.
Re: #4 spark plug smokes !
Here is video
https://m.youtube.com/watch?v=s2R1NHrSrJY
2017 Aprilia Tuono.
2017 Aprilia Tuono.
- SteveG
I say it is leftover oil / remnants cooking off. How far have you ridden the bike since putting it back together? If all of the plugs are tight, then ride it a good bit (100 miles at one stretch) and see if it still smokes.
My .02$
Nice bike!
Steve
My .02$
Nice bike!
Steve
Steve
Bike has been going through a customization. Motor was not run in last 3 years . I did valve adjustment, carb rebuild, oil pan cleaning , filter oil changes new plugs . Where would this leftover be burning ? Outside on valve cover ? Not sure why it would smoke only at near #4 cylinder
2017 Aprilia Tuono.
2017 Aprilia Tuono.
Are you sure you don't have a loose exhaust collar that blowing exhaust back through the head fins? That's what it looks like to me.
I will check that . These are new pipes with new copper round shape gaskets and I had tightened them fairly good while aligning.
2017 Aprilia Tuono.
2017 Aprilia Tuono.
Will try again. Collars are retightened as per manual. In the process, found that one of the stud On cyl #1 was turning free. Luckily I had a 6mm helicoil kit that took care of it .
2017 Aprilia Tuono.
2017 Aprilia Tuono.
- SteveG
Since you had the valve cover off to do the valve adjustment, some oil could have oozed/seeped/ran..... down into the #4 plug well/area while you were working.AshishNJ wrote: ↑Thu Jun 25, 2020 8:56 pmSteve
Is it still smoking after checking the exhaust crush washers as Dave suggested?
Steve
Steve. Haven’t had a chance to try due to rain. I hope it does not but we will see. I will setup an slr to take better video this time
2017 Aprilia Tuono.
2017 Aprilia Tuono.
I tested it out today and once engine heats up after 5 minutes or so, there is smoke from around spark plugs. No leaky exhaust. What I suspect is the inside of the valve cover gasket is seeping oil when it is him and hot and burns up. I touch around the gasket and I could see the oil ! I am guessing when I give it a throttle pump builds more oil pressure and immediately that leak also increases. Does my theory has a leg ?
2017 Aprilia Tuono.
2017 Aprilia Tuono.
Shouldn't be noticeable pressure build-up in the top end. Your valve cover gasket should not be seeping hardly any oil even if a cursory bit of care was taken during installation. Both cover and gasket should be thoroughly cleaned, then the gasket glued into the cover. Then just a dab of sealant around the 4 half-moons on the gasket and that should seal everything. I would suspect a pinched gasket somewhere causing the cover to not tighten down properly. Or else you have a very warped valve cover.
Dave. You have a point. The original valve cover I had was black color and was peeling off. I figured the engine should win beauty contest and decided to use another silver cover . It is possible the 2nd cover may have been warped, though it did not appear so. On a glass table it sat straight but at this point I will go back to older cover with new gasket. Those gaskets are not cheap ! Thanks for the advice.
2017 Aprilia Tuono.
2017 Aprilia Tuono.
While you have the cover off, be certain that the head surface is OK. A little nick, a scrape, etc. to cause a leak.
I will. Thanks
2017 Aprilia Tuono.
2017 Aprilia Tuono.
