Oil Pan / Starter Mounting Tabs Broken
- Location: In them thar hills- somewhere between Enon, Yellow Springs,and Springfield
Hi, so I am doing a restoration on an '82 Prolink and getting close to painting the motor and all parts / covers, etc.
I have a total of (3) cast parts with broken mounting "tabs":
Oil Pan
Starter housing
Primary cover
What can be done to repair these- short of hunting down new covers / housings?
Oil Pan
Starter housing
Primary cover
Re: Oil Pan / Starter Mounting Tabs Broken
Good used sump covers and sprocket covers are out there pretty cheap. And someone will have a junk starter you can rob parts from. Get the replacements - don't fool around trying to fix those.
Bigger question to me is this - if this much damage was done by a PO to these simple-to-remove parts, what other serious damage did he inflict deeper in?
I agree- that's the first thing I started thinking after looking at all of these broken tabs, but the inside of the motor is really clean, including the oil pickup screen. It hardly needed static valve adjustments ( from what we could tell without being able to start it). I've only had it running once before teardown because the carbs were pretty far gone from sitting so that's all I really know so far.
Can only find (1) used starter on ebay right now for $300. It appears to work but I only need the housing.
Contact Louis Mintrone at usedcbxparts. Or, come to Vintage Days this weekend.
You mean at Mid Ohio??Rick Pope wrote:Contact Louis Mintrone at usedcbxparts. Or, come to Vintage Days this weekend.
Yep, a bunch of us will be there. There's a tent in the infield sponsored by VJMC and ICOA with the "Birthday Bikes", from 1959, '69, and '79. I'll be the one who looks like Uncle Fester with a straw hat.
Tevan is another site member that probably has the parts you need.
That sounds awesome! I may just do that :)Rick Pope wrote:Yep, a bunch of us will be there. There's a tent in the infield sponsored by VJMC and ICOA with the "Birthday Bikes", from 1959, '69, and '79. I'll be the one who looks like Uncle Fester with a straw hat.
steve murdoch icoa #5322 wrote:Tevan is another site member that probably has the parts you need.
Thank you sir
