Front Fork Air Pressure
Anybody here running air caps on a 79? What pressure do you like them pumped up to?
Air Caps
Z GRAND - What difference have you noticed since running air caps on the early X?
Have you tried different pressures with any degree of change?
Has the addition of air caps with pressure created any leaking problems?
Any notice of different tire wear patterns?
How about front end wobble, has it increased or decreased or remained the same? That's if you had any wobble before.
Idle questions from an idle mind.
George in Delaware.
George in Delaware.
- Don
- Amazing Poster
- Z Grand
Re: Air Caps
The forks had been re-worked by Tim's using '80 model components before I bought the bike, so I can't really say how much difference there is vs. stock. I have not noticed any leaking, and the tire seems to wear very evenly. My bike also has a fork brace, so I have not noticed any front end wobble (though I admittedly don't ride the bike very hard). I've never run the bike without air in the forks, so I don't really know how much difference it really makes. Hope this helps.George R. Garrison #0857 wrote:Z GRAND - What difference have you noticed since running air caps on the early X?
George in Delaware.
