Fork Spring Installation
- SteveG
Hello all -
I'm changing the fork oil for the first time in my 82 and the fork springs have a tighter wind on one end than the other.
They were installed with the tighter wind at the top.
I couldn't find anything in the shop manual or this site that specifies which way they should be installed. The picture in the manual isn't clear either as to which way they should go.
This leads to two questions: 1. Are the stock 82 fork springs progressively wound? and 2. Which way are they supposed to be installed? (I have bad experiences just reinstalling things the way they were).
Just for info, the springs both measure 22.5 inches.
Thanks in advance, Steve
FWIW, aftermarket progressive springs are available for my BSA, and they stipulate that the more closely wound coils go on the lower end. Of course, that's next to no help to you at all, although I imagine the engineering realities behind that instruction would transcend marques. I'm sure someone else will call in soon....
Best Regards,
Brian
Best Regards,
Brian
1969 BSA Rocket 3
1976 Kawasaki KH400
1977 Yamaha XS650D Cafe
1978 Honda CB550K
1979 Honda CBX
1976 Kawasaki KH400
1978 Honda CB550K
1979 Honda CBX
- alimey4u2
- ICOA Web Video Director
- cbxtacy
The tighter end on the bottom just might lower the cg. Losing 10lbs of ugly fat will definitely lower it. I could do that so easy, I just might start on a program to make the cg of all my bikes lower . Should I lose 10lbs or make sure the tighter winds are on the bottom?
YOU'RE THE ONE
YOU'RE THE ONE
- cbxtacy
Lets get real anal here:
Assume the "looser" end of the spring compresses easier, means first when an impulse is transmitted through the front wheel.
If the loosely wound end is on the bottom, the spring compresses on the bottom first and leaves the upper part uncompressed or static. Turn the spring around and the upper part compresses first leaving the lower part of the spring static. Doesn't that mean, with a longer part static on the bottom, the unsprung weight is larger???
- cbxtacy
I don't know but being the greedy capitalistic pig that I am, I'm taking bids from prolink owners to some serious product evaluation for them regarding front springs and they're proper installation for superior handling.
As you can see, I will push a stock (more or less) CBX to it's handling limits . I will take a prolink CBX and run it with stock springs and with progressive (brand) springs. I will run them with the tight winds up and down. I will do it for $1000.00 (plus fuel used) and the results will be yours to peruse. And I will use the same track as in the photo. That's the cloverleaf intersection in NC at the intersection of I95 and Hwy87. Exit 46 on the interstate.
YOU'RE THE ONE
YOU'RE THE ONE
- SteveG
Sweet pic, "George I am" My main concern with the installation with tighter up or down was potential wear. I'm not the kind of guy that can feel those kind of differences in the suspension. But it sure did feel better with the fresh oil in it.
Can't wait to get it back on the road with the rebuilt shock and lubed bushings in the back
Steve
Steve
- cbxtacy
I understand, I'm just looking for some money for a free trip back to NC. Just don't tell anyone incase they took my last post seriously (seriously, do you think anyone would actually do that? (if they do, I hope they don't read this post (and I need to quit posting what I'm thinking, it gets me into trouble))).
YOU'RE THE ONE
YOU'RE THE ONE
Progressive wound springs are installed w/ the tighter coils to the top because that's the heavy end, thus less unsprung weight. Or, at least that's the theory. I doubt I could tell the difference on a CBX.
