Finally Got Ohlins Rear Shocks for the '79
ericfreeman
Post by ericfreeman »
I finally gave in and bought a set of HO 140 Ohlins rear shocks for my '79 CBX. The original owner was a noted auto drag racer in So. Cal and I think he raced the CBX in 1/8 mile events. I bought the bike from a good friend of his and when I got it the rear sprocket was a 51 tooth and the shocks were Konis with springs so stiff the rear was almost rigid. Probably good for the drag strip but not so much the street. I initially cheaped out with some Progressive shocks but soon dumped them for basic, non-adjustable Hagons, which were better but still very stiff. I weigh about 225 so definitely not underweight for standard rear springs.
Having reached the age of 68 and the bones are getting old and don't like overly stiff suspension. So, I ordered the Ohlins and OH MY, what a difference! The rear end is now much more compliant and doesn't bounce me off the seat (a stiff Corbin) like the other shocks did. I also fitted some RaceTech front springs and the bike is much more balance now and a pleasure to ride. Given the money wasted on the Progressives and Hagons, I should have bought the Ohlins from the start and I'd be about even now.
Now if I could just fix the oil consumption issue!
Re: Finally Got Ohlins Rear Shocks for the '79
Good for you, who’s going to buy them for you? If you got em, burn em, life is short!
