Hi All, I want to remove the side brackets as shown in pic.
Do I need to support the swingarm when I pull out the long bolt so shock stays in position.
Want to get in there behind to clean things up.
Removed the chain sprocket, unbelievable amount of dirt encrusted grease, underneath. Now clean as a whistle.
Removing side brackets
Re: Removing side brackets
Yes, support the swingarm. You can use the other through-bolt to follow the one you're removing.
If you don't have a spare pivot bolt, I've discovered that my Snap-On, 1/2" drive, 18" extension with do the job just fine.
Yes, good advice, will do this.
So did exactly as suggested, just took one long bolt out and followed it in with an extension. Got the one cleaned up, bit of grease on shaft, and good as new. Took one bracket off at a time, also cleaned them up, pretty filthy on backside. Like how Honda thought this out, one bolt goes in from left the other from the right. Works good, so you can remove one bolt and bracket, then the other.
All back together, along with new rear master cylinder kit.
Took out the battery bracket, and used high gloss rust paint to repaint some of the rusted areas, goes back in tomorrow.
