Hi all, are 19t or larger front sprockets available for a Prolink?
U.K.
19 tooth front sprocket.
Re: 19 tooth front sprocket.
Not exactly.
A late model Triumph has the same drive spline as the CBX but you'll need to space it accordingly. (Fabricate/machine a spacer).
Here's a photo of mine, JTF 1180-19
However, I would only recommend this for bikes with a 17" drive tire that you can't get a rear sprocket for.
These motors like RPMs, let it sing.
