Pump for air suspension
Hi Guys
This might be a silly question but how do you pump up the air suspension on a Pro-Link, normal car tyre adapter from a compressor won't work?
Re: Pump for air suspension
Read some more forums re the suspension, some guys saying don't worry about using air at all just, use some more oil, at the moment I have filled per the manual with ATF (amount of CC's as per manual) is the original rear monoshock OK if working or should I look at a new replacement?
Put a Progressive rear shock on and grease all the swing arm bushings when you do it. Big improvement over the old stock shock.
- Montana69
For the front I use a little bicycle pump, it's like a foot long and takes about 10 to 15 pumps to get to 10 psi. I don't think you should use a compressor, too much air too fast. The rear is a normal fitting for a tire/compressor.
1982 CBX1050
1970 CB750 KO
1971 CL450
1970 CB750 KO
1971 CL450
For the rear, what hondaman said is 'gospel'. Best money you will ever spend on prolink suspension. For the front, RaceTec gold valve inserts are a good bet.
What is a good progressive shock for the rear, I can get a this one http://www.wemoto.com.au/bikes/honda/cb ... monoshock/
Lots of people here have used the Progressive 465.
https://www.progressivesuspension.com/p ... ries-Shock
Might be able to find it $50.00 or so cheaper on Ebay, but that can have its own issues.
Thanks guys went with a Hagon shock as it was a better price and easier to source, all good now
Stevo, can you give us some info on the Hagon.
Model #, spring rate, price?
Progressive at Summit Racing: https://www.summitracing.com/parts/pgr-465-1115 $446 includes shipping.
I have a small hand pump by Fox that is intended for pressurizing mountain bike suspension. It seals to the valve stem before the core is depressed, and so it loses less than 1/2 lb of pressure when it is removed. Very accurate, very controllable, very affordable.
Example: http://a.co/3kdk9Ss
