'81 Fork Spring Dia
'81 Fork Spring Dia
I live in the twisty's, so every time I ride it's normally sport riding. My exhausts a being ground away and I'm wanting to space the front fork springs by 25-30mm
1"-1 1/4" to get the front up a tad in the corners.
Wanting to get them pre-made, so can just slip them in without waiting for the machine shop.
My question is. What is the standard front fork-spring diameter?
Regards
Daryl
Regards
Daryl
Re: '81 Fork Spring Dia
My question is: what exhaust are you running?
Seriously, if your front fork is set up properly, dragging the stock exhaust is near impossible. A bit heavier springs is probably OK, but you still need a certain amount of sag. If your forks are filled with 10 wt oil to within 6 inches of the tube tops, spring out and fork collapsed, then you'll not be dragging anything but the most ill-designed aftermarket exhaust. And if you are still running the stock rear springer, make sure it hasn't puked all it's oil and your are running max air pressure, or more. Better, get an aftermarket rear shock.
I’m running 10wt at 6”. Air to max good damping under compression and rebound. All indications are that the oils in suspension is right. Just the first initial fork dive and ride height not good.
What size rear tire? Smaller than stock will have things closer to the ground.
Everything else is stock. I'm just needing the front with less sag, so I'm wanting to space the fork spring 1".
- SteveG
I put the Progressive brand rear shock and Progressive brand fork springs in my 82 CBX and it completely transformed the bike. Well worth the investment.
Fork Springs: https://www.ebay.com/itm/Progressive-Su ... KM&vxp=mtr
Rear Shock: https://www.ebay.com/itm/Progressive-Su ... 2T&vxp=mtr
Steve
Steve
If the stock exhaust on a CBX is being "ground away" while riding on the street you should find a race track.Ibiro wrote:Everything else is stock. I'm just needing the front with less sag, so I'm wanting to space the fork spring 1".
Progressive front springs and an OLD Fox twin clicker on the rear made my '81 a decent back road rider.
Ditto on that, Steve. Made it a totally different bike. On the good side!SteveG wrote:I put the Progressive brand rear shock and Progressive brand fork springs in my 82 CBX and it completely transformed the bike. Well worth the investment.
Steve
Thanks for the input, as always sold experience based advice.
The exhausts are not stock pipes. Upped the fork pressure to 1.1bar and the clearance is way better for the twisty's, no exhaust dragging.
