Duraflow Stainless 6-6 System
Anybody familiar with these guys? 6-6 pipes look like Pipemaster.
http://www.duraflowexhausts.com/index-page13.html
[/list]
[/list]
They look quite similar to the Pipemasters but the ends of the mufflers are different and they appear to be one piece from header to muffler with no collector in the middle like the Pipemasters have
I know what you mean about the crashbars! It's good to keep as much weight down as low as possible, but still, you can carry a good thing a bit too far ;)
- cbxtacy
The bend in the pipe between the muffler and collector in the pipe Tony posted looks like there's a bend in it for clearance around the lower engine hanging bolt that would allow the pipes to give more ground clearance. Not that critical for most (how often do you drag stuff while cornering).
YOU'RE THE ONE
YOU'RE THE ONE
The bend is in the BSM exhaust also. The pictures do not show it well. I don't think it is for ground clearance, though. The muffler hangs on the brackets like the stock muffler. And the stock pipes have a slight indentation at that spot too.cbxtacy wrote:The bend in the pipe between the muffler and collector in the pipe Tony posted looks like there's a bend in it for clearance around the lower engine hanging bolt that would allow the pipes to give more ground clearance. Not that critical for most (how often do you drag stuff while cornering).
- cbxtacy
I emailed them about the pipes and received this answer:
Hi George,
At this stage I am unable to quote as the feight costs just keep going up
making my pipes very expensive and uncompetitive.
About a year ago it was CDN $ 2,700, so it could easily be over $3,000 now.
It is only available as a complete system, which presumably is with headers
(factory info not that clear).
Hi George,
YOU'RE THE ONE
YOU'RE THE ONE
- alimey4u2
- ICOA Web Video Director
Yes Powerflow from Durban, South Africa. Distributor advised this.EMS wrote:I may have mixed that up. But the name was something with "flow" and the exhaust was different from the Pipemasters. Maybe it was Powerflow?
I don't think it was Duraflow...
Apparently same company as referenced below:
http://www.powerflowexhausts.co.uk/history/
