This is the accessory fairing wiring I was referring to that was not on the early '81s. Later '81s and all '82s had it from the factory.
Optional gauges
Re: Optional gauges
What do you base this on, Dave? I have an early 81, serial number 113 and it has the instruments, thus the wiring.
Re: Optional gauges
A couple of things - From recollection, that is what I remember. Second, the part states exactly what it is for, so why would you need this if every Pro-Link already had one? It is an accessory part number, not a standard part number. I've installed the accessory gauges in 3 different Pro-Links and have original instructions somewhere for those gauges and in them somewhere it explains that you need this sub-harness if your bike does not have one. This implicitly means to me that some bikes did not have it. All three of mine did. That's what I know and remember, take it for what it's worth.
Re: Optional gauges
I know that if your Prolink did not have instruments, it probably did not have a sub harness. The question was how did you arrive on the assumption that early 81s were different to late 81s and 82s?
Re: Optional gauges
Again, the 3 Pro-Links I have put gauges in DID have the accessory harness. The rest I explained I think very clearly, the best I can.
- cross
Re: Optional gauges
My '82 didn't have any gauges but it did have the harness
Sasha
'82 Honda CBX
'99 Triumph TBS
'01 Honda Valkyrie
'82 Honda CBX
'99 Triumph TBS
'01 Honda Valkyrie
