Problem with headlight / turn signals
Posted: Thu Jul 01, 2021 1:32 pm
82 Prolink.
I put in a LED headlight, brake lamps, and front and rear turn signals, as well as the flasher unit for the LED's reduced power requirements.
They seemed fine for a few weeks but then things started going haywire.
When I hit either turn switch, both signal dash lights and turn signals would flash, and the headlamp would flicker.
Sometimes there was no issue, everything worked properly, at speed and constant throttle both signal dash lights and turn signals front and rear would flicker, or stay on or off altogether.
Thinking my issue was a faulty flasher, I exchanged it with another(happened to have a spare), but the same thing happened.
I then removed all the LED lightbulbs and headlamp, put in the old flasher, headlamp and all the old turn signal bulbs.
Before I put the glass cover back on, I turned the key on and headlamp shone brightly. So I installed everything.
BUT, I still have an issue, now my headlamp is very faint, barely on. its getting about 7.5 volts (with tester),
When I hit left turn switch, the front right signal lamp comes on and stays on, and the left one flashes very faintly,
and likewise when I hit the right turn switch, the front left turn signal comes on and stays on, and right flashes faintly.
The rear signal lights work properly, only the front is the issue along with the headlamp.
When either signal switch is not on, both front turn signal lamps are on, which is good.
Electrical stuff is not my forte. Can any one guide me on troubleshooting this issue.
