So, I have tried to locate the fuses for this bike but I am stumped. *The main 30 amp is a no brainer but....They are supposed to be behind near the rear brake reservoir but I simply can't find em. Who knows where the PO possibly rerouted the fuse to??? I have unscrewed the terminal block on the right side and chased the loom to god knows where and no fuses??? I know there are 5 glass fuses somewhere. I feel dumb not being able to find them.
Thank you in advance,
Sky.
fuses location
Re: fuses location
Have you looked at the fuse carrier by the ignition switch?
Re: fuses location
Right below the ignition switch under the plastic cover as previous reply saidDynamohum wrote:Have you looked at the fuse carrier by the ignition switch?
- desertrefugee
Re: fuses location
The one that says "FUSE" on it.tevan wrote:Right below the ignition switch under the plastic cover as previous reply saidDynamohum wrote:Have you looked at the fuse carrier by the ignition switch?
Re: fuses location
Really? It actually has " FUSE" written ?desertrefugee wrote:The one that says "FUSE" on it.tevan wrote:Right below the ignition switch under the plastic cover as previous reply saidDynamohum wrote:Have you looked at the fuse carrier by the ignition switch?
*go to my garage, check my CBX *
Huh! It does say "FUSE"
