common headlight problems?
So I finally got my carb problem sorted, finally got the engine to run and how awesome it sounds. But now I see the headlight isn't turning on. I've checked the bulb, fuses and starter switch, but not too sure if theres any other common problems that cause the bulb to not turn on. Also not sure if its supposed to be always on, or on after starting the bike. Bike is a '80 US model. Hope someone can chime in. Thanks!
