Currently rebuilding my alt. and will replace the rubber gromment at the bottom of the cover where the wires come through. Would like to pull the 5 wires out of the plug in connector to save on cutting them and repairing them ...What's the trick to release the spades from the connector?
Being ever so careful not to harm the connector. Thanks
alternator rubber gromment question
Re: alternator rubber gromment question
See my reply on the other thread. Biggest pain by far is fishing all those wires through the 90 degree rubber grommet. Lots of lube and patience.
Hi Dave Did you remove the connector or cut the wires??
Remove the connector! Do you still need help figuring out the female connector removal?
trying to release the wires from the back of the connector. do insert my tiny screwdriver at the top of the wire or the bottom of the wire to release the brass tab?? tried for 30 min and no go!! Thanks
