Carb sync tool
- cross
Carb sync tool
Hi guys,
I would like to know what tool you are using for syncing carbs.
There are great reviews for Morgans carbtune.
One of my friend has twinmax, electronic sync tool but it is only for two carbs at a time.
How much of a run around will I have using two port electronic unit versus 4 port vacuum sticks?
Twinmax also has great reviews.
I see that Honda manual states tool number for their sync tool and I think it's only with 1 port.
Any input appreciated
Thank you
Sasha
Thank you
Sasha
Sasha
'82 Honda CBX
'99 Triumph TBS
'01 Honda Valkyrie
'82 Honda CBX
'99 Triumph TBS
'01 Honda Valkyrie
Re: Carb sync tool
I use the Morgan Carbtune and love it. I just have the 4 tube one and tie the other 2 together with a hose and rotate after I get 5 6 and 4 done.
- ajs350
- cross
Re: Carb sync tool
Both of these are my options. Dial gauges bounce too much so they very hard to read.
I'm leaning towards morgan carbtune pro even though I would really like twinmax.
Not sure if it's really necessary to have gauge for every carb as the adjusters are for pair of carbs.
I think that part number that Honda has in the manual is a single port gauge, maybe twin.
Sasha
'82 Honda CBX
'99 Triumph TBS
'01 Honda Valkyrie
'82 Honda CBX
'99 Triumph TBS
'01 Honda Valkyrie
Re: Carb sync tool
No, each adjuster does only one carb, but also effects those downstream. 6 gauges are the way to go if you can. And the set shown has damping screws so you can nearly eliminate bounce. Dirty little secret is that if you fiddle to get perfect sync, go for a ride, then check them again, they'll be off a bit. The linkage is just too springy for holding perfect sync. But if you get them close, you'll have a sweet sounding CBX at idle and the rpms will drop back to a nice idle as well.
- cross
Re: Carb sync tool
Is there a write up on here somewhere on bench syncing?
Sasha
'82 Honda CBX
'99 Triumph TBS
'01 Honda Valkyrie
'82 Honda CBX
'99 Triumph TBS
'01 Honda Valkyrie
Re: Carb sync tool
Read some of Dave's posts in this one. Might/should help you with the bench synching thing. viewtopic.php?f=20&t=6964&hilit=bench+synchingcross wrote:Thanks
- cross
Re: Carb sync tool
I bought the six gauge set and will attempt to sync them,
I'll post the results
Thank you
Thank you
Sasha
'82 Honda CBX
'99 Triumph TBS
'01 Honda Valkyrie
'82 Honda CBX
'99 Triumph TBS
'01 Honda Valkyrie
Re: Carb sync tool
Where did you buy it from?
- cross
Re: Carb sync tool
If I rememember correctly it was on Amazon. I got set of 4 and a set of 2.
I couldn't find set that comes with 6.
Sasha Krstich
Sasha Krstich
Sasha
'82 Honda CBX
'99 Triumph TBS
'01 Honda Valkyrie
'82 Honda CBX
'99 Triumph TBS
'01 Honda Valkyrie
Re: Carb sync tool
Any idea of the cost? I've seen a 6 set on eBay for around 250 and was thinking I could buy six individuals and mount them on a board.
- cross
Re: Carb sync tool
I think I paid about 110/120 for both
Sasha
'82 Honda CBX
'99 Triumph TBS
'01 Honda Valkyrie
'82 Honda CBX
'99 Triumph TBS
'01 Honda Valkyrie
- spencer
Re: Carb sync tool
If you get analog gauges, just make sure they are adjustable, so you can synchronize the gauges before you synchronize your carburetors. I bought a set of six, and they are not adjustable, and don't all read the same. Useless. I use a Carbtune now.
SCH Rochester, MN
