Accelerator pump rod travel
- Kool_Biker
Re: Accelerator pump rod travel
I bow to your vast experience and include a pic of my disassembled pump, in case you can see something I don't. For a minute I thought I had erroneously used the air cut off valve spring in the accelerator pump, which is shorter, but no such luck. It is slightly narrower so would not fit properly. And in any case, the maximum travel of the rod is set by its diaphragm end, 'bottoming' internally against the pump case (pushing on the brass valve bottom) ... it is in no way limited by the spring.
Puzzling ...
Puzzling ...
Aris Hadjiaslanis
ICOA # 6309
Berkshire, Windsor
ICOA # 6309
Berkshire, Windsor
- Kool_Biker
Help!
Anybody got a picture of the 79 Z fuel pump o-ring, preferably sitting on the no 3 carb bowl.
I have managed to mix mine with few more - and I am pretty sure the one shown here is too big reducing or even choking the output flow of the pump?
Thanks, Aris
Thanks, Aris
Aris Hadjiaslanis
ICOA # 6309
Berkshire, Windsor
ICOA # 6309
Berkshire, Windsor
Your o-ring is too large. It is a pretty thin one - there is no other like it on the CBX carbs.
I was having some trouble posting a pic with my narrative but shown above are a couple of shots of my 79 #3 carb with the correct O-Ring.
Hope that helps!
Hope that helps!
6Pipes wrote:I was having some trouble posting a pic with my narrative but shown above are a couple of shots of my 79 #3 carb with the correct O-Ring.
Hope that helps!
After you upload the picture to the Gallery, you open it again, scroll down below the picture where you see ImageBBCode and then copy the id from the window which in this case says [album 4401 album] and paste that into your post like this:
- Kool_Biker
Thanks chaps, this is really helpful.
With your pictures above, I have now positively identified the correct o-ring!
Many thanks for the excellent response.
Aris
P.S. Now I have some definite flow, back to getting the infamous pump rod to behave when opening the throttle. That is:
1. Travel long enough. Up to ~6mm according to Mike
2. Fast enough. This should be easily achieved with a stiffer spring, adding some washers to the existing set up, etc.
BTW here's a Utube link to the first ever start of my partially built CBX a few days ago ... good oil pressure though
Apologies if it is sounds Greek to you, that's what it is ...
Aris
Aris Hadjiaslanis
ICOA # 6309
Berkshire, Windsor
ICOA # 6309
Berkshire, Windsor
Aris,
I enjoyed your video! What a great shop you have.
Aris! Awesome! Hope you don't mind, I edited your post to put your video in the 'youtube' tag to embed it directly.
- Kool_Biker
Success at last!
With the help of your pics I located the correct o-ring, reassembled the carbs, primed them and woo-hoo, the results as below.
And a pleasant side benefit, for those who have followed the entire blog, the accelerator rod travel has improved.
It now moves faster, more responsively from rest to it's stop.
The only explanation I can give is, the pump is no longer working against a blocked output? Maybe.
Thanks for all your support guys. We are getting there!
Aris
Aris
Aris Hadjiaslanis
ICOA # 6309
Berkshire, Windsor
ICOA # 6309
Berkshire, Windsor
- Kool_Biker
Almost 3 weeks after my last post above and lots of test runs of my now completed Z, I would like to thank the forum and in particular all you gurus for guiding but also challenging me with your recommendations to get my accelerator pump right.
Pick up on the throttle is now, to me at least, excellent and I look forward to many riding miles in the near future to prove under various road conditions.
If there is a lesson to be learned by us mere mortals is that with the forum resources, time, common sense and most important of all, perseverance you can really get things right in the end.
Cheers, Aris
Cheers, Aris
Aris Hadjiaslanis
ICOA # 6309
Berkshire, Windsor
ICOA # 6309
Berkshire, Windsor
Ahem. Did you say "completed'?Kool_Biker wrote:Almost 3 weeks after my last post above and lots of test runs of my now completed Z...
Cheers, Aris
Pics and a video or it didn't happen!
Very impressive Aris. Can't wait to see it.
- Kool_Biker
Nils, kudos to you and all the good people supporting us!!!
I will submit a video the day I get one, with pleasure.
Meanwhile may be some of you will be interested in a video of my GL 1000 K1, completed about a month ago, which by the way was the winning entry in a Randakk competition! Apologies if the place is inappropriate but the passion is the same, it's only the bike model that's different :)
http://www.youtube.com/watch?v=5NdViMxrGeU
Enjoy in hi resolution!
Best, Aris
Here's my Z, fully functional and ready for the road, less a couple of stickers and with my test exhaust as I haven't made my mind yet what to get in the end (opinions welcome!).I will submit a video the day I get one, with pleasure.
Best, Aris
Aris Hadjiaslanis
ICOA # 6309
Berkshire, Windsor
ICOA # 6309
Berkshire, Windsor
Outstanding. That's what, 4 CBXs restored here in the last 12 months? Fantastic.
Great job Aris, it looks mint.
