1981 Auto fuel petcock
Posted: Tue Apr 04, 2023 6:27 pm
by Bruce Witherspoon
Has anyone found a source for a rebuild kit for the vacuum controlled fuel petcock?
It has fallen victim to fuel with the addition of good old ethanol and leaks profusely as soon as I open the tank mounted petcock.
Any leads would be greatly appreciated.
Bruce
Re: 1981 Auto fuel petcock
Posted: Wed Apr 05, 2023 8:46 am
Keeeeel eeeeeeet. They are so much easier to start after a layoff without it. New fuel line and a brass tee and the deed is quickly done.
Posted: Wed Apr 05, 2023 11:47 am
by Larry Zimmer
Yep --- get rid of the valve. Just remember to turn it off ALWAYS whenever you stop. You won't forget to turn it on! (Not for long!)
Posted: Wed Apr 05, 2023 3:17 pm
by CBX-tras
Like this. I use a Ford style inline filter from the '70's. 5/16" hose inlet, 1/8npt out:
Posted: Wed Apr 05, 2023 7:49 pm
It looks like the only alternative is to remove the valve. Turning off the petcock is no big deal. I had a 79 back in the day and that was what we did then.
Thanks guys! I will still probably take the valve apart to see if there is a work around.
