Hi. I have a 1981 CBX1000 Prolink and am looking for a 2nd hand accelerator pump housing.
Cheers
Mark
I seem to have lost the inner 1-way valve in mine ?
Any help in sourcing a good 2nd hand one would be highly appreciated.Accelerator pump housing
Re: Accelerator pump housing
The heat and vibration in an ultrasonic cleaner can shake these apart, removing the square brass piece, spring and ball bearing that acts as a check valve. I no longer clean them in the machine with the rest of the parts for that very reason.
Although not sold as a service part by itself, it's the exact same component as any Honda DOHC 4 of that era.
Those may be easier to find in your area.
Many thanks for the reply. I think I may have found one off a GL1500 ?
I'll be more wary of my ultrasonic cleaner in future :)
The parts are probably still in the bottom of the tank.
That cover was never sold as the single part, so, I can't confirm that the GL part will fit/function properly.
I'll let you know when I get it :)
