A Learning and a Question
tian647
Post by tian647 »
I have been slowly fettling my neglected CBX, poor thing has been shuffled off to a dark corner of the garage and infrequently dragged out into the light such that age and idleness overcame fork seals, carburetor gaskets and brake calipers, etc.
I have been dreading re-installing the carbs until I finally worked up the courage (or sought refuge from our over-staying house guests) to head out to the garage and tackle this challenge. I did, this time, arm myself with a tip from this forum: heat the manifold boots until they are uncomfortably warm to the touch." Wow - they popped right on with hardly any pressure, like they were drawn in by magnetic attraction. Hell, if I had known that step would have been that easy I'd have been riding my bike this summer already...
I am now attending all the remaining loose fasteners hoses and cables and have one that I can't quite positively identify - a plastic barb clipped onto the top of the clutch cover, shown in the attached [and inverted?] photo. I think it is meant to attach to the float bowl 'spider' for the overflow vents - can anyone confirm I have it right?
Thanks all!
Christian
'79 CBX
Re: A Learning and a Question
At least now i know where my over-staying house guests ended up.
You are correct, even upside down that is still a "joint, overflow".
https://www.ronayers.com/oemparts/a/hon ... comp-parts
tian647
Post by tian647 »
Brilliant - thank you!
Christian
'79 CBX
