Choke Shafts?
Choke Shafts?
I know there is a difference between the left & right choke shafts, can someone send me a picture of the left one on the spring end.
I was not the one who took them apart and didn't identify left from right.
The previous owner kept the carbs numbered in 6 coffee cans, so he did that right!
Thanks in advance!
Darryl
Thanks in advance!
Darryl
- desertrefugee
Re: Choke Shafts?
Maybe this will help - courtesy of Mike Nixon:Darryl's CBX wrote:I know there is a difference between the left & right choke shafts, can someone send me a picture of the left one on the spring end.
Thanks in advance!
Darryl
(they look the same to me)
https://www.youtube.com/watch?v=uLhJM4oRRmo
From your other brother Darrell (really)
Re: Choke Shafts?
According to Mike Nixon's Book they are different, but he dose not say how to identify left from right.
Thanks for the reply Brother Darryl!
Re: Choke Shafts?
Hi,
Second half of Mike's video is the left side. Here's a picture:
Paul.
Paul.
Re: Choke Shafts?
Hi Paul;
There is just a pink rectangle but that is all, please try again.
Darryl
Darryl
Re: Choke Shafts?
Wait it just showed up, Thanks again!
Darryl
Darryl
Re: Choke Shafts?
They are absolutely self - explanatory when you get to reassembling them. The left won't go into the right the whole way and vice-versa. Springs are right and left too, but you should be able to figure it out. Holler if you need more help.
Re: Choke Shafts?
Thank you I will.
Darryl
Darryl
